Gouge In Oak Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 01-05-2012, 08:09 AM   #1
Shooloo2
gouge in oak flooring
I love this site already! My son (I love him dearly) put a nice gouge, at least 1/4" deep and 1/2" long in our oak floor. Do they make a product that I can use to fill this in and then cover it over to match the color?
Shooloo2 is offline   Reply With Quote
Old 01-05-2012, 10:00 AM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Find a hidden area that you can sand to create a little oak dust and mix it with a little Elmers to make an exact match if you can't find a putty that will match to your liking.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 01-05-2012, 01:45 PM   #3
DIY staff
Rewards Points: 7,174
I use a ' shellac stick' "burn in stick'--'lacquer stick'
It's old school but works well---The stick melts when heated with an alcohol lamp or torch--
Surrounding area gets masked off with aluminum foil- shellac melted onto a burn in tool or artists pallet knife---spread carefully into damage---then sanded with very fine sand paper on a wood block.
Add a little new varnish or wax the area and done---
The sticks come in a bunch of colors---Mike---
Old 01-05-2012, 01:50 PM   #4
Rewards Points: 13,276
And if that does not work it's a simple job to just remove that one board and replace it. The hard part is matching the old finish.
May not be a DIY job.
Lumber Liquidators Bud Cline Flooring 11 10-28-2011 03:00 PM
asbestos in our ripped up flooring?? 6fthook Flooring 16 07-30-2011 12:06 AM
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 1 10-08-2010 09:53 PM
Fix/hide/improve gouge in hardwood flooring Leah Frances Carpentry 4 11-23-2009 02:39 PM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 09:00 PM
