Gorilla Glue Removal - Flooring - DIY Chatroom Home Improvement Forum
Like Tree5Likes
  • 2 Post By Termite
  • 1 Post By Yodaman
  • 1 Post By Oso954
  • 1 Post By MTN REMODEL LLC
Old 05-05-2008, 11:44 AM   #1
Gorilla Glue removal
What is the best way to get gorilla glue off engineered wood surface?
Johnhere is offline   Reply With Quote
Old 05-05-2008, 01:39 PM   #2
J Calvin Construction
jcalvin's Avatar
Rewards Points: 150
Use a grinder and throw all your gorilla glue away. There are many other types of glue on the market that holds just as good without the expanding and running problem. I have used it twice, and screwed up the project both times.
Cal
You hired WHO?
jcalvin is offline   Reply With Quote
Old 05-07-2008, 03:34 PM   #3
Registered User
Termite's Avatar
Sanding will usually remove the glue residue that scraping doesn't. Gorilla glue doesn't take stain, so wherever it is exposed or where it penetrated the wood grain, you will see it.
It is a good glue for some projects, but when doing carpentry and woodworking that needs to look nice, I leave it on the shelf.
MTN REMODEL LLC and Yodaman like this.
Old Yesterday, 07:11 AM   #4
Rewards Points: 8
Re: Gorilla Glue removal
What is recommended for removing GG from painted wall [yes, drip marks galore] AND as an all-purpose tough-as-nails, hold-all glue for dry and wet surfaces? Keep in mind that I am a novice, newbie, uninformed, wannabe.
slamet is offline   Reply With Quote
Old Yesterday, 08:36 AM   #5
Rewards Points: 482
use the white gorilla and it doesn't foam the brown color does
del schisler is offline   Reply With Quote
The Following User Says Thank You to del schisler For This Useful Post:
slamet (Yesterday)
Old Yesterday, 08:47 AM   #6
Rewards Points: 8
I appreciate the response but it doesn't solve the current problem I have of GG drips showing on off-white painted surfaces. How do I remove or minimize the effect? What should I use going forward for complete hold in wet AND dry environments as GG doesn't do well in wet.
I am not adept nor have access to a grinder, much less refinish tools/ abilities afterwards. I need something to wipe off GG from painted wall. And what should I use going forward for WET and DRY surfaces?
Old Yesterday, 10:52 AM   #7
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,344
I know of no solvent after GG is dry... If a smoth surface, I'd try carefully a razor blade.... if rough, I think you are sanding and refinishing.
As to a choice of glues, maybe you ought to tell us what you are glueing and the exact onditions. Glues vary significantly as to setting conditions and streangth.
GG is fine even great in moist conditions.... matter of fact, moist helps it set.
MTN REMODEL LLC is online now   Reply With Quote
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
slamet (Yesterday)
Old Yesterday, 10:54 AM   #8
I've never tried the white... I thought / assumed it was just a wood glue with a GG label... no different than Titebond/elmers/etc.
slamet (Yesterday)
Old Yesterday, 11:39 AM   #9
Rewards Points: 8
Final Attempt to explain my NEEDS:
I am truly a novice and housewife with no access to tools, excepts liquids and wipes, to remove GG so suggestions of sanders, grinders etc. are of no value & of no help. I have used GG for everything from gluing wood to wood, stick-on battery-operated light to wall and rubber feet to ceramics so as to make fancy soap dishes for the shower.
GG has NOT been successful for any of these endeavors. After a short period, the bond breaks and I am left with separate pieces from which I have to pry off the GG the best that I can [unsuccessfully]. Any USEFUL, HELPFUL suggestions for my circumstances for my worst nightmare, that of removing GG drip from painted surface, under these circumstances and a substitute for GG in these instances going forward are most welcome and appreciated.
I count on you experienced guys to take the place of my father who knew everything, passed in 2004 @ 86, and who would have guided me towards the right answer... Please, no more grinders or sanders!
Old Yesterday, 12:09 PM   #10
Well... Please excuse us for trying but being bad fathers.
Old Yesterday, 12:43 PM   #11
Property Mgt/Maint
Rewards Points: 1,504
I think what the fine folks here are telling you is: there is NO miracle wipe off solution after it is dried. It has to be scraped or sanded.
slamet likes this.
Yodaman is online now   Reply With Quote
The Following User Says Thank You to Yodaman For This Useful Post:
slamet (Yesterday)
Old Yesterday, 12:47 PM   #12
Rewards Points: 8
That is what I was missing - the honesty and the brutality. Thank you for bringing that to my attention. I needed it desperately! YOU ROCK for taking the big step. I will now seek a handyman who will do that for me. Bless you for you honesty and forthrightness!
Old Yesterday, 01:28 PM   #13
Oso954's Avatar
Rewards Points: 1,302
Deleted
Nik333 likes this.
Oso954 is online now   Reply With Quote
Old Yesterday, 01:38 PM   #14
See post 7
lenaitch likes this.
Old Yesterday, 09:24 PM   #15
Usually Confused
lenaitch's Avatar
Rewards Points: 1,958
'Gorilla' is a brand of adhesive that sells several products. The sell a wood glue that is ok but not my favourite. Their original glue is an water-activated expanding polyurethane that should be good in wet locations.
From your examples of failed attempts:
"wood-to-wood": should have worked with either glue provided the surfaces were clean and smooth. If it was exterior, it might have been that movement of one or both of the surfaces failed the join.
"stick-on battery operated light to wall": many adhesives don't perform well on non-porous surfaces, so if the back of the light was metal or plastic that might explain it. You might have had better luck with 2-sided tape. If the attempt was to glue the thin edge of a fixture to a wall, there likely wasn't enough surface area.
"rubber feet to ceramics": may be the same as above since ceramic isn't porous. Also, most things we call rubber, aren't, but rather, some form of petroleum-based polycarbonate. I find it very difficult to successfully glue most forms of 'plastic'.
lenaitch is offline   Reply With Quote
Removal of old glue hstgonzo Remodeling 4 05-02-2008 03:34 PM
Installing glue down engineered floor brad4499 Flooring 6 03-12-2008 09:54 AM
Wood Glue Issue gp1200r Carpentry 4 02-20-2008 11:56 AM
Why is my living room cement floor covered with black glue? sil Flooring 7 10-29-2007 10:03 PM
