Good Product To Fill Cracks In Concrete Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 10-25-2010, 10:20 AM   #1
Rewards Points: 101
Good product to fill cracks in concrete floor
Im looking for suggestions, preferences, and opinions on concrete crack fillers. My garage floor has a number of settling cracks in the floors. The hous is only 6 years old but I think the builder didn't put any reinforcing mesh so it has cracks at least since I moved in a year ago. These cracks range from mostly hairline to a couple cracks that at maybe 1/16" wide. Most of te cracks are web and flush, there about to or three of the wider ones with a small offset around 1/16". I have seen a couple possible ways to patch. One would be converter patcher that you mix and trowel. Another is premixed crack filler that is supposed to pour, but is still kinda thick. Then I have seen concrete crack filler in a caulking tube that says it is self-leveling. Are any of these better than the others? Also, I may want to later use an epoxy paint and wound would like to fill the cracks as smoothly as possible with something that will hold the paint.
wvphysics is offline   Reply With Quote
Old 10-25-2010, 11:49 AM   #2
jlhaslip's Avatar
Rewards Points: 2,132
Hydraulic cement is a powder that you mix with water and trowel into the cracks.
Check a Hardware store or one of the big box stores
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Repair on Concrete Drive Way Cracks jamiedolan Building & Construction 4 08-17-2010 11:40 AM
Dog urine soaked through floor on concrete Speckert General DIY Discussions 2 06-02-2010 09:20 AM
How to cut a hole in a concrete floor slab tomseeley General DIY Discussions 7 06-10-2009 02:32 PM
Concrete deck -- rotting floor joists jwill Building & Construction 6 09-05-2007 08:01 AM
