A good laminate underlay
2 Attachment(s)
Thanks for all the help so far and I certainly apologize for the newbie questions one after another.
I removed the old carpet in one of the rooms yesterday, and I also removed the tack strips along the walls (using the Super Wonder Bar), some 'relatively' significant amount of concrete came off along way (pictured). Will the holes become a problem for laminate flooring? Should I fill the holes with some sort of filler? I plan to get the Kronotex Dynamic range (8mm) laminate, what would be a better underlay (mainly sound proofing) for it? My local store carries the Roberts Harmony (pictured), is it among the better ones? Thanks in advance. |
http://www.solidsoundusa.com/SolidWalkLT.htm (You can check around for other similar products on their web site) |
cork underlay works nice if the manufacturer approves.
If I remembered correctly, the fiber pad (SolidWalk/QuietWalk look-alike) costs twice as much as the Harmony. Interestingly, the Harmony is actually similar or better in terms of IIC/STC rating (possibly in biased control environment): I wonder what the competition has to say about this: Quote:
Having said that I'm tempted to get Harmony. |
How about those looks like cheap stuff selling in HD, red plastic sheet with those small white circular form stuff inserted, HD didn't offer other choice... ? Should I return all of those?....
| All times are GMT -4. The time now is 02:36 PM. |
