Going Through Doorways - Flooring - DIY Chatroom Home Improvement Forum
Old 08-19-2011, 11:19 PM   #1
Going through doorways
This is my first time installing a hardwood floor (I've done laminate). One thing I am not clear on is going through doorways. I am doing living room, hallway, and 3 bedrooms. How do I continue into the bedrooms?
What I mean is, when I lay the last row in the hallway, do I continue through the door openings with the boards facing the same direction or should I stop and start from the far wall in the bedroom? And the bedroom at the end of the hallway, should I cut the boards in the doorway and run them in the bedroom 90 degrees to the hallway?
Zilvar is offline   Reply With Quote
Old 08-19-2011, 11:51 PM   #2
Tile with Style
BlueStoneFloors's Avatar
Be more specific...Are you referring to the pattern, or cutting, or what?
BlueStoneFloors is offline   Reply With Quote
The Following 2 Users Say Thank You to BlueStoneFloors For This Useful Post:
Bud Cline (08-20-2011), ttr13r (08-27-2011)
Old 08-21-2011, 03:45 PM   #3
Thanks I figured it out from reading different articles.
Old 08-21-2011, 04:51 PM   #4
DIY staff
Rewards Points: 7,174
There you go--I'll bet that article told you about 'splines' that allow you to reverse the nailing directions.
Old 08-21-2011, 08:02 PM   #5
You're exactly right, the only problem is the flooring store where we purchased the hardwood doesn't have the splines. In fact the saleslady had no idea what I was talking about. After making some phone calls, she said the installers cut their own. Do you guys make them yourselves or buy them? Do they come in different sizes? Thanks
Old 08-21-2011, 08:10 PM   #6
DIY staff
Both---Menards has splines in packs of four---However they didn't fit the Bruce groove(to fat) so I made my own.
Typically the hardwood distributor has ones to fit---If not---table saw time.
Old 08-21-2011, 09:30 PM   #7
Do they have to be hardwood?
Old 08-21-2011, 11:18 PM   #8
DIY staff
Yes,but not necessarily oak--Maple-- cherry--poplar---whatever good strong wood you have.
Zilvar (08-22-2011)
Old 08-23-2011, 10:21 PM   #9
Success!!! I've found the splines in Home Depot, they call them "Slip tongue" and they are 4' long made out of oak. Didn't have a chance to try for fit yet.
The Following User Says Thank You to Zilvar For This Useful Post:
oh'mike (08-23-2011)
Old 08-23-2011, 11:45 PM   #10
DIY staff
I like to cut back the tar paper under the boards that are to be splined and glue them to the sub floor with PL premium---saves you from face nailing the boards,
BlueStoneFloors (08-24-2011)
Old 08-24-2011, 12:27 AM   #11
That's a good tip. Is the tar paper used to prevent squeaks or block moisture? Since I have a finished basement, do I still need this underlay?
Old 08-24-2011, 01:23 PM   #12
Rewards Points: 200
Tar paper , or felt as we call it is a moisture retarder , not a barrier . it does help with squeaks. Yes you still need the felt . roll it out to the length you need and flip it , it will lay flat for you . I use Aqua bar B myself , they cost about the same now that felt doubled in price.
Floor Doc is offline   Reply With Quote
The Following User Says Thank You to Floor Doc For This Useful Post:
Zilvar (08-24-2011)
Old 08-24-2011, 03:02 PM   #13
Tile with Style
I'm not a wood flooring expert, but we've always double layered the roofing felt and it worked out great. One layer East-West One layer North-SouthNo squeaks and quieter in general, imo.
Hell is 8 months of nothing but slate work...
Help selecting wood to trim out interior windows and doorways RobertN Carpentry 11 01-07-2011 05:38 PM
Going through doorways with laminate compounder Flooring 6 06-20-2010 04:55 AM
expansion gaps and doorways? adjason Flooring 4 07-02-2009 07:59 AM
Fly Control for Restaurant with Open Doorways ToddSpitz Pest Control 3 06-29-2009 01:51 PM
headers for basement doorways Railz Carpentry 3 12-15-2008 11:47 AM
