Gluing Plywood To Concrete - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-04-2010, 03:30 PM   #16
C W
Originally Posted by GDiak View Post
Ok, but what is the best way to do this? Nobody has really told me !!!! Anybody that knows, please let me know !!
not reccomended and void of waranty from any flooring manufacturer!
C W is offline   Reply With Quote
Old 12-04-2010, 05:19 PM   #17
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 82
Originally Posted by KarlJay View Post
Found a few sites that may have a solution for you. I don't know if LL has a good enuff rep to be followed, but worth looking at.
http://video.bobvila.com/m/21320495/...r-concrete.htm
I wonder if you could just put the floating floor closed cell foam under some 3/4" plywood and nail the hardwood to that.
My house was built in 1937 and has some kinda tar and then some tile (looks like asbestos tile), the problem is that I've replaced some of the foundation and that's an area that I want hardwood over.
If these options don't work well, then what is the solution? (other than going with a floating enginered floor)
Liquid Lumberdators has a well deserved bad reputation.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 12-05-2010, 03:03 PM   #18
Applying glue to slab or below grade concrete is a very bad idea. Concrete wicks up moisture from the earth around it, which will break down the adhesive bond. Additionally, this moisture will build up under the floor, causing the bamboo flooring to swell and buckle, and it will eventually develop mold, rot, mildew, and foul odors. It might take ten years, but it WILL happen.
You have three good options:
1. Install a plastic vapor barrier underneath the floor-- at least 10mil.
2. Install a plastic sub floor -- but don't use those tiles they sell at Home Depot -- the wood chips in it extend 1/4" beyond the tiles and has the same basic problems as wood on floor.
3. Use a concrete sealer to seal the floor, then add the floor as a floating floor. Don't use those waterproof paints, as they tend to flake and peel away.
Let me know if I can help with anything else.
ConcreteTreat is offline   Reply With Quote
The Following User Says Thank You to ConcreteTreat For This Useful Post:
GDiak (12-07-2010)
Plywood over concrete jlweber Flooring 16 10-07-2011 07:13 PM
concrete drive and walk 7echo Landscaping & Lawn Care 12 04-22-2011 05:03 PM
Damp Concrete Garage Floor Tom S. Building & Construction 15 03-27-2010 08:23 AM
gluing wood to concrete kathy k Carpentry 11 08-16-2009 10:51 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
