Gluing Floating Floors And Engr Vs Solid - Flooring - DIY Chatroom Home Improvement Forum
Old 07-21-2011, 06:44 PM   #1
Question
Gluing Floating Floors and Engr vs Solid
We pulled up our old carpeting and found particle boards underneath. Both HD and Lowes said we needed a floating floor. Lumber Liquidators said it could be glued. What's your opinion? Also, anyone pull up particle board flooring to install plywood so they could install solid hardwoods? I heard of someone doing this and don't know if it's feasible.
Diane111 is offline   Reply With Quote
Old 07-22-2011, 06:02 AM   #2
woodman58's Avatar
I would not recomend glueing wood over PW. With the moisture in the glue it will cause the PW to swell slightly. Tacking up PW is sometimes a pain. It depends on how it was put in. If it was screwed or they used ring shanked nails, it will be a pain. If it was just nailed it should be easy.
woodman58 is offline   Reply With Quote
Old 07-22-2011, 06:50 AM   #3
We have a few boards to pull up and we haven't done that yet! I'm hoping it goes smoothly. Appreciate the insight. (I'm from St. Louis and was just there.) Thanks for the help.
Old 07-29-2011, 10:01 PM   #4
Please don't ever glue down a floating floor. Besides the fact that you will void the warranty, you will ruin the floor, probably the subfloor and have a huge mess on your hands. The key to a good installation is like anything else...building a solid foundation, stable, moisture free, level, etc. You aren't the first person I've heard that has said Lumber Liquidators told them not so accurate info. That Rusty guy and OMike and there is another here (Bline-something or other?) on this chat site seem really knowledgable and helpful with details.
ttr13r is offline   Reply With Quote
Old 07-29-2011, 11:23 PM   #5
particle board is not suitable under nail/staple down solid hardwood flooring.
don't believe everything they tell you at the big box stores. also if you are considering buying flooring from LL do a search and read what people have to say about them and their experiences with LL. depending on you sub floor you shouldn't have to install plywood over it to install solid hardwood. the floating floor would work over the particle board. some engineered flooring can be floated, stapled or glued down. always follow the manufacturers installation instructions.
Old 07-30-2011, 12:27 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
A key notion of effective salesmanship is to "never bring negatives into a conversation" and when negatives do arise " quickly negate them to close the sale".
In the case of the big box stores, bad information comes from mostly ignorance of the field, in the case of Lumber Liquidators bad information comes from the above salesmanship notion.
REMOVE THE PARTICLEBOARD.
XXX
Old 09-14-2011, 05:28 AM   #7
Engineered hardwood flooring is the perfect option for many homeowners and businesses. First, engineered hardwood uses less of the premium hardwood making it more eco-friendly than most solid hard wood. Secondly, engineered hard wood flooring can be used in a floating floor installation over concrete, but can also be used in a glue down floor installation. The installation flexibility of these floors also adds an element of dimensional stability that makes engineered wood floors a perfect choice for heavily trafficked areas, or just about anywhere in your home or office. If you’ve been looking for the best price on engineered hard wood floors, you’re now only one click away from finding them.
tectonicfloors is offline   Reply With Quote
Old 09-14-2011, 07:14 AM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Whatever all of that means!!!
Old 09-14-2011, 09:59 AM   #9
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 182
It means he sells that product and has a link in his profile.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
Bud Cline (09-14-2011)
