Gluing Bamboo Stair Treads - Flooring - DIY Chatroom Home Improvement Forum
Old 04-04-2010, 11:52 AM   #1
Rewards Points: 87
Gluing bamboo stair treads
What should I use to glue bamboo stair treads? I went to HD and they recommend Roberts 1408 but it only comes in 5 gallon there. (I can order 2 gallon online but it's still too much for my need, only 3 steps for now) Can I use construction adhesive ? If so what kind? Thank you.
A picture is worth a thousand words.
Stephen S. is offline   Reply With Quote
Old 04-07-2010, 12:32 AM   #2
Just get the quart tubes of construction adhesive , And a quart caulking gun , do it that way all the time never a call back ,You need an old board to set the tube on because it will drip . tacomahardwoodfloors.com The reason is the const adhesive will stay firm and not flatten out till you force the tread onto it , that will help ensure the board is seated in the low spots . . I don't put a lot on , Just a strip every 6 or 8 inches
tacomahardwood. is offline   Reply With Quote
The Following User Says Thank You to tacomahardwood. For This Useful Post:
Stephen S. (04-14-2010)
New stair treads and flooring rickkeeter Flooring 2 02-24-2010 10:16 PM
Ugly old painted stair treads, with seriously raised grain. Salvageable? CharmCityFixer Flooring 9 01-29-2010 06:40 PM
Botched stair treads Garance Carpentry 1 11-05-2009 04:56 PM
installing stair treads. Wild Duk Flooring 4 05-20-2008 09:56 AM
Scribe Cutting Oak Stair Treads kcdave Carpentry 2 03-18-2008 07:13 PM
