-   -   glueless Vinyl product (http://www.diychatroom.com/f5/glueless-vinyl-product-1432/)
NoviceDIY 12-07-2005 07:42 PM
Hi, I am new here. Have you heard of this product or used it before? http://vinylflooring.org/?gad=CNmRwq...it2JD-AyC_hMcJ They sell glueless vinyl products that are made of fiberglass along with other material.
The reason I am considering this is I have two layers of sheet vinyl in my kitchen. I had it tested and for sure it contrains asbestos. I do not want to remove them for health and cost reasons.
Since I am replacing everything in my kitchen, I would like a new floor but my choices are limited since I do not want to remove the existing vinyl. I could lay a 1/4 inch birch plywood as my underlayment and lay another sheet vinyl, but this will raise my floor too high.
This particular product (they have a 12 minute movie on their website) looks like what I can use: they can lay on top of 2 layers of vinyl; no glue is needed if the area is less than 25 squre yards; price is quite reasonable.
The only problem is I can not actually see in real life. I did order a sample from them, but I think it is just a very small piece.
Has anyone used this product and can provide some feedback of how you feel about it?
Floorwizard 12-08-2005 08:48 PM
This is the next big thing for vinyl.
So far it has worked great. And installers like it because it's dang near immpossible to tear.
Ash74 01-04-2008 09:36 AM
We sell something like this at the Home Depot made by Armstrong and personally, I hate it.
It's a good DIY product for small areas with low traffic and that's about it.
Biggest complaint I've run into is having to re-lay the floor. Use and tempeture changes will cause it to come loose and need to be re-laid and re-attached every six to twelve months. Also, the vinyl isn't any more durrable than a standard 10 yr warrenty vinyl from any other company.
Keep in mind I've only worked w/ one brand of product. Others may be much better to work with in the long run.
Floorwizard 01-04-2008 11:34 AM
Yes, there are many other qualities in this type of floor now.
Albi 08-18-2010 08:44 PM
Don't buy glueless vinyl flooring!
:( Pushed by the contractor, I went ahead and had my large kitchen done with a high quality glueless vinyl. At first, it looked wonderful. Then the vinyl started waving in one area, then in another area. Every day I seem to discover another problem. My old standard vinyl had lasted twenty years without the least bit of problem. On the other hand, this glueless vinyl started acting up only a few months after the installation by a respected local man who has done this type of work for years. So, you have been warned, DON'T BUY THIS TYPE OF VINYL!:(
poppameth 08-19-2010 05:57 AM
The problem is that everyone wants to install it as a loose lay. Install it with the correct adhesive full spread and most of these problems never appear. Flexitec's calls for rolling the glue on with a paint roller. There isn't anything difficult at all about it. We only loose lay this stuff in very specific circumstances.
rusty baker 08-19-2010 06:35 AM
Most of the loose-lay problems are caused by improper installation.
poppameth 08-20-2010 05:52 AM
Also true. I've heard of plenty of buckling issues and usually no double faced tape was used in areas where it should have been, such as under the refrigerator.
