Old 07-02-2009, 10:16 AM   #1
STB
Question Glued Floor vs Floating floor
I live in Orlando, FL and I'm getting ready to install a hardwood floor over my concrete slab. We are installing the following floor
The Millstone Collection “aka” Timeless Textures
Classic Series
Maple
DTMPBZ / BRONZE
9/16"x5"x RL 7ply
Were trying to figure out wich is better, glue it down or float it. I've had two different companies tell medifferent things. One says glue it the other says float it. Any help would be appreciated.
STB is offline   Reply With Quote
Old 07-03-2009, 12:54 PM   #2
Still Learning
The middleman Forest Accents says nothing about floating, but it looks like the same product manufactured in China packaged and sold by many in the US including Garrison, Naturally Aged, Johnson to name a few. Some say float while others say not to.
Give FA a call.
Custom Wholesale Floors
You can reach us directly by phone at:
1-866-4 Accents (1-866-422-2368)
or by fax at:
(904) 281-7706
Corporate Office Address:
2655 Dawin Rd N
Jacksonville, FL 32207
HardwoodGuy is offline   Reply With Quote
More On This Topic
Learn materials needed for silkscreening at home and how to screen print a shirt in this free video on silkscreening, or screen printing, clothing. Read More »
The next exercise is called single leg lift. So, inhale and on the exhale just gently float one leg up to table top position. Inhale here and exhale gently float it back down to the floor. The idea is that the contraction in your lower abs is so strong... Read More »
Isolation in your recording studio needs to be at the front of your mind. Improper isolation will result in rumble, bleed and unwanted resonance in your recordings. One of the places you need to consider isolation is in your floor. Rumble and vibrations... Read More »
There is no reason to throw out a chair because of a loose chair rung. Fixing a loose chair rung is quick and easy to do. It is a great skill that allows you to fix flea market finds and garage sale cast-offs, or just to prolong the life of your existing... Read More »
Crow Pose in Vinyasa Yoga
Crow Pose in Vinyasa Yoga by Expert Village
The next series I am going to show is an arm balancing. So you can come into a squat position separating your feet a little bit out to point the toes out to the side. Take your palms to the floor, take your knees up into your arms and start to float your... Read More »
Floating Floor Repair justbcz Flooring 6 07-06-2009 09:13 PM
Floating floor underlayment question sxn77 Flooring 8 05-07-2009 03:37 PM
floating vinyl floor phatibs01 Flooring 1 04-05-2009 07:31 AM
Kitchen floating floor JFD140 Carpentry 4 08-25-2007 01:28 PM
Floating floor in odd shaped house Yodels Flooring 2 12-19-2006 11:42 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
