Old 12-18-2012, 03:45 PM   #1
Glued Down Carpet Removal!
I found the ultimate carpet removal machine! Its called a Tearout Trike and it saves big on labor (It's actually fun to use). If you're a contractor or if you do a lot of demo work you should check this thing out.
***link removed as per the rules***
AlexReid is offline   Reply With Quote
Tags
carpet, carpet damage, carpet installation, carpet over glue, carpet removal
Problem with carpet glued to asbestos tile and want to replace... bobcaryh Flooring 7 11-29-2011 01:15 AM
asbestos problem under glued down carpet lisacolin Flooring 7 01-12-2011 03:34 PM
Basement carpet removal hellothere123 General Discussion 1 11-02-2009 09:39 PM
Carpet Glued On OLD linoleum-HELP gradlass Flooring 5 09-30-2007 09:26 PM
glued down carpet...can I cheat? Dusty Flooring 3 10-10-2006 06:18 PM
