Glue On Wood Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 07-21-2011, 09:44 PM   #1
Rewards Points: 27
Glue on wood flooring
i just installed some bamboo flooring in my house and wasnt as clean as i wanted to be so there is some of the adhesive residue over parts of the floor. Do you guys know what is the best way to get it off with out damaging the finish?
woodenSpoon is offline   Reply With Quote
Old 07-21-2011, 10:45 PM   #2
Rewards Points: 558
Purchase a bottle of goof off from your local home improvement store this multipurpose stain remover acts as a solvent that will quickly dissolve the glue from your floor. Read and follow the instructions on the product label for how to apply the solution.
epson is offline   Reply With Quote
The Following User Says Thank You to epson For This Useful Post:
oh'mike (07-22-2011)
Old 07-25-2011, 05:45 PM   #3
Rewards Points: 27
i tried some of this and it made the wood look really dull, is there a way to bring back the shine or is there another product that i can use
Old 07-25-2011, 06:32 PM   #4
Rewards Points: 558
You can buff the area with car wax to take the dullness out.
Old 07-27-2011, 03:32 AM   #5
It is a good idea, I had the same problem some time ago, but never fix it. Now i'll try this method.
alain33 is offline   Reply With Quote
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Moisture barrier for laminate wood flooring Blotz Flooring 2 08-05-2010 07:39 PM
Anyone covered stained concrete flooring with wood? jcieutat Flooring 11 12-12-2009 11:19 AM
Bathroom wood flooring options? JamesEric Flooring 6 03-28-2009 09:03 AM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
