-   -   Glue together floating floor, bouncy from un level subfloor (http://www.diychatroom.com/f5/glue-together-floating-floor-bouncy-un-level-subfloor-179553/)
palabalo 05-14-2013 10:56 AM
I installed an engineered wood floor, glue together tongue and groove, I leveled the sub base but missed a few spots. Primarily a spot that we replaced the 3/4 inch sub floor with 22/32inch I thought the slight difference wouldn't matter, but it does.
This creates a little bouncy area where you can feel the floating floor flex from level to touching the subfloor then back to level.
I have access to the sub floor below (laundry room unfinished).
The thought is to drill a small hole from the bottom (or multiple) and inject something, glue, sand, silly putty? something. to level out the sub floor in the areas I need.
Anyone done this or have any advice?
MJ Force 05-14-2013 11:28 AM
I wonder if construction adhesive injected using a chaulking gun would work? A 4" square pattern/grid of holes could be carefully drilled. How large is the area?
palabalo 05-14-2013 11:49 AM
Most of the 4x8 board
MJ Force 05-14-2013 12:10 PM
So one sheet of ply. That's not too bad.
If you choose the injection method stay off that area for a few days until the glue cures. I'm concerned about the movement afterwards on the floating floor. Is this in a small area/room? 100-200 sq ft. Might be ok.
palabalo 05-14-2013 12:56 PM
Total area connected 400 sq ft,
but the shape is a bit odd, kitchen to living room to hall all connected. I feel like there is room for the wood to expand on both sides of the "glued area"
What type of caulk would you use?
MJ Force 05-14-2013 01:08 PM
Not chaulking. A good construction adhesive will flow into those holes and then puddle in the void. Don't pump in too much. You want to create a small pad of glue about the size of a quarter. That way it will cure quickly. Use at least a 4" grid pattern of holes. Of course try to avoid drilling into the underside of the new flooring.
MJ Force 05-14-2013 01:12 PM
Ps; construction adhesive comes in a tube. PL-xxx. (400?) or PL-premium construction. You use a chaulking gun to pump it. Then it dries hard.
palabalo 05-14-2013 01:15 PM
Well I think I am going to try this out, seems reasonable what can go wrong :-)
I am going to wait a bit to see if someone has a better thought but I think this is what I am going with.
MJ Force 05-14-2013 01:18 PM
I've never had to do this but it sounds like a remedy that just may work.
MJ Force 05-14-2013 01:22 PM
Maybe try a few test holes first to see if there's any results. After that, if it works, complete the rest of the holes.
