Glue Down Hardwood On Vinyl Tiles - Flooring - DIY Chatroom Home Improvement Forum
Old 07-25-2011, 12:38 PM   #1
Glue Down Hardwood on Vinyl Tiles
Is it possible to glue down hardwood on vinyl tiles?
I knew that my floor is a concrete slab so I prepare to glue down my hardwood floor on it. When I removed the carpet, I found that there is vinyl tile (small square pieces) before concrete. Can I glue down my floor right over it? Do I still need moisture barrier in this case?
Thanks in advance.
thone is offline   Reply With Quote
Old 07-25-2011, 02:28 PM   #2
woodman58's Avatar
I would not reccomend gluing wood over vinyl tile. There are to many prblems that can arise. One being that the tile have been down for a long time. The glue is probably going to break down in the future. This will cause the floor to start moving and you to have to replace the entire floor to soon.
woodman58 is offline   Reply With Quote
Old 07-25-2011, 02:35 PM   #3
what type of hardwood? engineered? it will only be as good as the floor under it. what are you gluing it down with? gluing down 3/4 thick hardwood could cause problems. hardwood expands and contracts with the seasons.
The Following User Says Thank You to DannyT For This Useful Post:
thone (07-27-2011)
Old 07-25-2011, 05:16 PM   #4
Should remove tiles.... if black glue underneath you will have to encapsulate with cement/polymer coating.
HarryJ is offline   Reply With Quote
The Following User Says Thank You to HarryJ For This Useful Post:
thone (07-27-2011)
Old 07-25-2011, 06:29 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You should research that a little further thone. Not all of those flooring adhesives are going to be compatible with prior adhesives or cement/polymer coatings. Whatever they are.
The thing to do is to ask the adhesive supplier this questions and not depend on any BS from an Internet forum in this case.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
thone (07-27-2011)
Old 07-27-2011, 12:21 AM   #6
Thanks all for info. That helps me a lot, I was about to put the floor over it.
I used putty knife to pop one of the tile which is very tight and I can see the concrete. I saw yellow glue, (yay! not the black glue). Is it polyurethane? Is polyurethane cleaner will be effective?
I plan to use MAPEI moisture barrier once I remove all tiles and level the concrete then glue down. Please advise.
BTW: It's 3/8" hardwood and 3" plank.
Old 07-27-2011, 07:54 AM   #7
yellow is good. I wouldn't use a cleaner on it, just scrape it up the best you can and then apply the mapei. You're on the right track.
Can I glue down an Armstrong locking hardwood floor? Fixitgeorge Flooring 10 01-30-2013 11:49 AM
How To Dispose Vinyl Asbestos Tiles? jbk Flooring 5 03-20-2011 06:20 PM
Traffic Master Peel off Vinyl Tiles fishtayl Flooring 4 11-02-2007 11:56 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
