Glue Down Engineered Wood Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 03-02-2011, 09:58 PM   #1
Glue down engineered wood flooring
Can you glue engineered wood over wood tiles?
mh8888 is offline   Reply With Quote
Old 03-02-2011, 11:35 PM   #2
Coatings Nerd
www.northcromwellpaint.com
Benjamin Moore, Sikkens, TWP, PPG, Airless sales and service
NCpaint1 is offline   Reply With Quote
Old 03-03-2011, 06:12 PM   #3
Use a trowel down urethane adhesive and in theory it will work just fine. But it's not a great idea, to many layers of potential failure. Whatever you do, don't use a latex or water based adhesive.
Mikef5000 is offline   Reply With Quote
Old 03-06-2011, 12:14 AM   #4
I have old 9" sq. wood floor tiles and it would be a big job to remove the old tile and install new. I figure maybe I can glue the new engineered flooring on top of the old wood floor tiles? Would that work?
Old 03-06-2011, 12:47 PM   #5
Coatings Nerd
Old 03-06-2011, 01:50 PM   #6
Handyman
Rewards Points: 512
Is the flooring click style or nail down?
canadaclub is offline   Reply With Quote
Old 03-06-2011, 02:20 PM   #7
woodman58's Avatar
Old wood glues dries up over time. It is not like the glues of today. More than likely the parquet that is down will come up fairly easy. Use a pry bar and a hammer to beat between the parquet and the floor under it. Because it is probably dried out you need to take it up. It will break down and become loose before your new floor wears out. (start crackling) I would take it up.
On the other hand, if it is an engineered that can be floated then you can go over it, but there is still a chance that the floor underneth will still get loose and start crackling.
woodman58 is offline   Reply With Quote
Old 03-06-2011, 06:24 PM   #8
I have glued down engineered floor. Can I glue down over my existing floor with another engineered floor?
Jfmaturo is offline   Reply With Quote
Old 03-06-2011, 07:22 PM   #9
I have 1/2" thick engineered floor. The sales rep said I can nail, glue or float but suggested glue down is best. Since my old wood tiles seem to be very firmly glued down, I figure maybe I can glue over it?
Old 03-06-2011, 07:30 PM   #10
Handyman
Rewards Points: 512
1/2" engineered..more like 5/8" it's a nail down .I suppose anything with PL can be glued ,,time will tell. Personally, I like to err on the side of caution and do the job right.
Bruce Turlington engineered wood flooring???? Oxymoron Flooring 1 01-10-2010 11:06 AM
engineered wood flooring flugalbinder Flooring 1 05-06-2009 11:51 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
engineered flooring - advice please colbard Flooring 2 10-28-2007 11:25 PM
Engineered Flooring in Kitchen Hages Flooring 1 03-29-2007 02:30 PM
