Glue Down Engineered Wood Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 03-06-2011, 06:38 PM   #1
glue down engineered wood floor
Can I glue down engineered wood floor over an existing engineered wood floor>
Jfmaturo is offline   Reply With Quote
Old 03-06-2011, 07:20 PM   #2
No. The existing wood floor is glued down to concret and is very solid. Can it be done?
Old 03-06-2011, 07:24 PM   #3
DIY staff
Rewards Points: 7,174
JFmaturo--Let's see what a floor pro has to say about this----
Old 03-06-2011, 07:56 PM   #4
woodman58's Avatar
It is not recomended to do this. As I stated in another thread older types of wood glue will break down over time. This type of floor may be stable now but may not be in a couple of years. But If you have to do this you would have to sand the finish off of the bottom layer. This would give something for the new glue to stick to. Again, this floor may not last.
woodman58 is offline   Reply With Quote
The Following User Says Thank You to woodman58 For This Useful Post:
oh'mike (03-06-2011)
Old 03-06-2011, 08:08 PM   #5
DIY staff
There you go---If you feel that taking a risk on the stability of the existing flooring is worth the time saved in removing it.---Sand the old wood and glue down the new---
Old 03-06-2011, 08:27 PM   #6
Thank you everyone. Now I can make a decision.
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 10:07 PM
engineered wood floor on radiant heating hikergirl99 Flooring 0 02-17-2010 03:18 PM
tarkett / engineered wood floor installation momof2labs Flooring 13 12-08-2009 06:21 PM
Faulty engineered wood floor installation? bobbo Flooring 15 08-30-2009 10:19 AM
Where to buy adhesive for engineered wood floor SoConfused! Flooring 2 12-04-2006 10:21 PM
