Glue Down Carpet Removal Prior To Platon - Flooring - DIY Chatroom Home Improvement Forum
Old 10-07-2016, 11:25 PM   #1
Rewards Points: 2
glue down carpet removal prior to platon
I'm getting ready to lay down platon underlayment, xps foam panel and osb or plywood in my basement. The previous owner had very cheap indoor/outdoor carpet heavily glued straight to the slab. After plenty of struggling and patients I removed the carpet...but there are tons of spots where leftover fibers are still adhered to the concrete.
Here is my question...do I have to remove it all? I've tried a couple methods and it would take an excessive amount of time to completely remove it all. I know you do not want any organic material stuck underneath the platon...but wouldn't this leftover carpet be all synthetic fibers? Is it ok to just cover it up as is?
One other question I haven't been able to find an answer for anywhere...if I'm not doing the entire basement, should I be taping/sealing up the platon where I stop? (which will not be at a wall) Same question for the floor drain...cut around the drain and tape/seal the platon to the floor?
Please let me know if theres something I missed.
Thanks for reading and I look forward being a part of the site!
glue down carpet removal prior to platon-img_20161006_202436247.jpg   glue down carpet removal prior to platon-img_20161006_211429906.jpg
chester_d13 is offline   Reply With Quote
Old 10-08-2016, 09:08 AM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 42
Re: glue down carpet removal prior to platon
Just leave it. When the platon fails, which it will, you can clean it then.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 10-08-2016, 09:38 PM   #3
Rewards Points: 3,414
Yes you have to remove it all, instructions state all debris needs to be removed before installation.
Don't know what your trying to achieve here, but why not direct your questions to the Mfg.
Canarywood1 is offline   Reply With Quote
Old 10-09-2016, 04:46 PM   #4
Rewards Points: 42
The platon system is a failure waiting to happen, anyway.
Old 10-09-2016, 06:13 PM   #5
If you have first hand information, or a link to a site providing their failure rate, would you be willing to share it, as it would benifit everyone.
Old 10-10-2016, 12:18 PM   #6
Rewards Points: 42
I have torn up dozens of those floors. They all mold. I have never seen one last more than five years.
Of course, I only started installing in 1973, what do I know.
Old 10-11-2016, 10:34 AM   #7
Rewards Points: 2
For those interested - after trying a few different methods, klean strip adhesive remover is doing the trick... though still relatively slow.
Good call, I will contact the manufacturer about sealing edges as the instructions don't address this. I could see both ways making sense for different reasons. Thanks.
Are you able to provide and opinion on a solution rather than using a membrane underlayment? Do you feel like straight XPS is better? I've read/heard countless opinions/experiences on both sides of the argument. Seems that's there's no agreed upon method.
Old 10-11-2016, 02:24 PM   #8
Your using a razor scraper right, usually comes up pretty good with one of those.
Old 10-11-2016, 02:51 PM   #9
Rewards Points: 2
Yes using a scraper. I'll have to use some sort of abrasive for the imperfections and dips in the concrete. A wire cup brush seems to work .
Tags
basement , floor , platon
wallpaper glue removal bubbler Painting 20 12-31-2014 06:36 AM
Glue Vinyl Carpet Runner richapple Building & Construction 5 11-09-2014 01:27 AM
Prepping a cement floor for tile. Carpet glue removal?? Lavid2002 Flooring 6 06-07-2012 05:41 AM
Cost to remove cutback (black glue from carpet removal) elanna2 Flooring 8 03-23-2012 04:07 PM
Carpet cleaning - sump water n0c7 Flooring 17 08-29-2011 08:04 AM
