Glass Tile Adhesive Ooze - Flooring - DIY Chatroom Home Improvement Forum
Old 10-21-2010, 10:56 PM   #1
Glass tile adhesive ooze
I'm using a mastic tile adhesive to install 1 X 1 inch glass mosaic tile sheets on plywood for a countertop. The tiles are only about 1/8 inch thick and when I press the sheets into the adhesive, it oozes out of the joints between the tiles. Does anyone have any ideas about other adhesives or installation methods? I don't want to spend hours cleaning adhesive out of all those little tiles! Thanks!
WINST10 is offline   Reply With Quote
Old 10-21-2010, 11:12 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 388
Huh, glass tile on a counter, with mastic, on plywood. That's strike 3, you're out!
Where did you get the idea you should do that?
I don't think you should be using glass on a counter. Definitely not on plywood with mastic.
You should be using a white premium thin set mortar rated for glass. You should have first installed a cement backer. I'd check with the manufacturer about using their glass on a counter. I'l bet the answer would be "not recommended".
Jaz
Glass on greenhouse roof Flavio Building & Construction 16 07-15-2010 07:37 AM
Install glass tile on wood stud pole (for support beam) chatelain Remodeling 1 06-21-2009 10:45 PM
Glass Tile Installation hms2205 Tiling, ceramics, marble 2 06-20-2009 07:46 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
