Old 11-01-2012, 01:42 PM   #1
Question
Gilly
Can I install ceramic tile over ceramic tile?The existing tile is installed on concrete.
dgilly is offline   Reply With Quote
Old 11-01-2012, 04:15 PM   #2
JetSwet's Avatar
Gilly
It depends. How high of a glaze content is on the prior tile? You will have to scuff the surface And then set with a two part thinset like Kerabond and Keralastic by Mepei.
JetSwet is offline   Reply With Quote
Old 11-01-2012, 04:49 PM   #3
Unhappy
Gilly
The tile is in the bathroom and shower. 2" square slip resistant.
Old 11-01-2012, 05:18 PM   #4
Gilly
Alway better to remove the old tile.
Just going over it will through off the baseboards, where it meet the other floors, the toilet flange, door casings.
ToolSeeker (11-02-2012)
Old 11-01-2012, 05:26 PM   #5
Unhappy
Gilly
The shower is quite large and all tile. Do you think it would be OK to lay the new tile over the old?
Old 11-01-2012, 06:28 PM   #6
Gilly
How would you lay tile over tile in a shower and have the drain come out right?
Old 11-01-2012, 06:38 PM   #7
Wink
Gilly
Use longer screws for the drain strainer
Old 11-01-2012, 08:41 PM   #8
Gilly
that would work for the drain but it may not work for the shower controls.
Old 11-01-2012, 09:33 PM   #9
Tileguy
JazMan's Avatar
Gilly
He's axing about setting new tiles over old tiles on the floor (concrete) not walls.
Get Extend-O-Drain for the shower drain strainer. http://www.homedepot.com/buy/extend-...l#.UJMhXY5jNOQ
Tile over tile can work well as long as everything is in good condition and properly prepared. It's a good idea to scarify or use a special primer on the old tiles. Here's one I've used. http://www.mapei.com/public/US/produ...rip_TDS_EA.pdf
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
The Following User Says Thank You to JazMan For This Useful Post:
Old 11-02-2012, 09:07 AM   #10
Wink
Gilly
Thank you gents. I think I have it now
