-   -   Gilly (http://www.diychatroom.com/f5/gilly-161834/)
dgilly 11-01-2012 12:42 PM
Gilly
Can I install ceramic tile over ceramic tile?The existing tile is installed on concrete.
JetSwet 11-01-2012 03:15 PM
It depends. How high of a glaze content is on the prior tile? You will have to scuff the surface And then set with a two part thinset like Kerabond and Keralastic by Mepei.
dgilly 11-01-2012 03:49 PM
Ceramic tile
The tile is in the bathroom and shower. 2" square slip resistant.
joecaption 11-01-2012 04:18 PM
Alway better to remove the old tile.
Just going over it will through off the baseboards, where it meet the other floors, the toilet flange, door casings.
dgilly 11-01-2012 04:26 PM
Ceramic tile
The shower is quite large and all tile. Do you think it would be OK to lay the new tile over the old?
joecaption 11-01-2012 05:28 PM
How would you lay tile over tile in a shower and have the drain come out right?
dgilly 11-01-2012 05:38 PM
Ceramic tile
Use longer screws for the drain strainer
DannyT 11-01-2012 07:41 PM
that would work for the drain but it may not work for the shower controls.
JazMan 11-01-2012 08:33 PM
He's axing about setting new tiles over old tiles on the floor (concrete) not walls.
Get Extend-O-Drain for the shower drain strainer. http://www.homedepot.com/buy/extend-...l#.UJMhXY5jNOQ
Tile over tile can work well as long as everything is in good condition and properly prepared. It's a good idea to scarify or use a special primer on the old tiles. Here's one I've used. http://www.mapei.com/public/US/produ...rip_TDS_EA.pdf
Jaz
dgilly 11-02-2012 08:07 AM
Ceramic tile
Thank you gents. I think I have it now
