Getting Tile Up Wothout Damaging - Flooring - DIY Chatroom Home Improvement Forum
Old 10-29-2013, 07:03 PM   #1
Rewards Points: 878
The last tile as you can see is about a 3/4 tile. We would like to try and get it up without damaging the other tiles because we would like to lay a full tile down that will go over the pipe. How can we get these tiles up without doing damage to the others ? Thanks a lot!!!
Getting Tile Up Wothout Damaging-photo-2.jpg   Getting Tile Up Wothout Damaging-photo-1.jpg
Mstrlucky74 is offline   Reply With Quote
Old 10-29-2013, 07:28 PM   #2
Rewards Points: 14,300
#1 Copper pipe should not be in direct contact with the concrete.
It should have been below the slab not sitting on top of it.
I also never would have used copper, I'd have used Pex instead. That way there's never going to be corrosion to deal with later.
Just laying a tile on top of that gap is not a great idea. Anything gets sat on it and it's going to snap off.
Remove the grout and cut an X with a 4-1/2" right angle grinder with a diamond blade across the middle of the tile.
Now just bust it up with a hammer.
Unless someone did a pore job of installing it, it's not coming out in one piece.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
gregzoll (10-29-2013), Live_Oak (10-30-2013)
Old 10-29-2013, 07:37 PM   #3
Rewards Points: 878
I was going to lay grout over the pipe to fill in the gap and make it level. We channeled out the concrete to put the pipe in the channel. As#ho$% guy I know did this. Can't believe he did not say anything. I guess maybe I will change out the pipe to PEX. Can PEC be joined with copper? Thanks.
Old 10-29-2013, 07:50 PM   #4
Rewards Points: 878
Thanks Joe. Whats the best way to remove the grout?
Old 10-29-2013, 07:55 PM   #5
I use an oscillating saw with a diamond blade. far more control that way.
http://www.zorotools.com/g/00094713/...m_campaign=PLA
Old 10-29-2013, 07:56 PM   #6
Rewards Points: 6,652
Multi-tool is the best way. Something like this http://www.harborfreight.com/power-t...ing-tools.htmlIf you have a Harbor Freight, check their clearance section, since you can sometimes find open box tools back there cheaper.
Old 10-29-2013, 09:00 PM   #7
If you do not own or have never used a Muliti Tool you'll find lots of uses for it.
I own two of the Rockwell brand and use them a lot.
If you buy the blades on Amazon they can be a whole lot cheaper if you buy them in quantity. $6.00 each as opposed to up to #20.00 in the box stores.
Old 10-29-2013, 09:26 PM   #8
Tileguy
JazMan's Avatar
Rewards Points: 422
I own a Craftsman & a Harbor Freight, (for laughs). I've used both dozens of times. Every handyman needs one of these tools.
The original and best is the Fein MultiMaster, but at about $400 I recommend one of the others until you outgrow it.
Great for tile removal. http://www.multimaster.info/en_us/versatility/#4
Jaz
JazMan is online now   Reply With Quote
Old 10-29-2013, 09:55 PM   #9
JazMan, I actually wore out two of the Plunge blades, trimming Gyprock, when we put in our new backdoor. I have a Harbor Freight unit, and that sucker stands up to even wives using them.
Old 10-29-2013, 10:02 PM   #10
I use a Roto Zip and a tile cutting bit for Gyprock or a 4-1/2" right angle with a diamond blade.
That stuff is tough on any tool and the lungs.
I bought a dust guard attachment for the Roto Zip, it works OK not great.
Old 10-29-2013, 10:15 PM   #11
I have worn out a tile cutting bit also with the Gyprock in my place. That stuff is just tough, after 75 plus years.
Old 10-30-2013, 04:50 AM   #12
Rewards Points: 878
Thanks guys . What about the cooper pipe issue?
Old 10-30-2013, 01:22 PM   #13
Remove it and replace with PEX.
Old 10-30-2013, 01:39 PM   #14
Registered User
Rewards Points: 526
http://www.pexsuperstore.com/resources/
Gary
Old 10-30-2013, 07:07 PM   #15
Rewards Points: 878
Can I wrap something or insulate the cooper pipe? Someone mentioned this to me.
Help! Wall Tile Repair with No Substrate? LauraFixItGirl Kitchen & Bath Remodeling 15 06-06-2013 11:28 PM
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
Travertine Tile Help MikeinTexas Flooring 1 09-07-2011 10:43 AM
Carpet over tile without damaging tile.. jill2shay Flooring 2 08-03-2008 09:53 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
