Getting Tile And Thinset Up - Flooring - DIY Chatroom Home Improvement Forum
Old 03-01-2014, 06:55 AM   #1
Rewards Points: 878
Getting tile and Thinset up
Hello, I laid three tiles with thinset. What is the easiest way to get them up? I think I can just cut the tiles with a grinder but I'm worries about the thinset being a bit#% to get up. It's going to be cured and very hard. I don't have to take these tiles up but I would rather. If it's going to be very hard to remove the thinset I might just leave it Thanks
Mstrlucky74 is offline   Reply With Quote
Old 03-01-2014, 07:00 AM   #2
DIY staff
Rewards Points: 7,174
What material is the tile/thinset stuck to?
Concrete? a chisel or scraper will usually get it up---
Durrock? You might have damaged backer board to repair---not a big job with three tiles---but one more thing to do----
Old 03-01-2014, 07:06 AM   #3
Rewards Points: 878
Originally Posted by oh'mike
What material is the tile/thinset stuck to? Concrete? a chisel or scraper will usually get it up--- Durrock? You might have damaged backer board to repair---not a big job with three tiles---but one more thing to do----
Concrete ....
I noticed....... a year ago my life became one big DIY project ever since...lol..geeez..
Old 03-01-2014, 07:13 AM   #4
DIY staff
Thinset comes off of concrete easily enough---I use a sharp painters tool and a small hammer----an old wood chisel will work---but might make a woodworker cry---
As to removing the three tiles---scrape out the grout as well as you can---get a small hammer--and start tapping in the center of the tile---remove the center first ,then gently pry out the remains---
Old 03-01-2014, 09:00 PM   #5
Rewards Points: 878
Thinset comes off of concrete easily enough---I use a sharp painters tool and a small hammer----an old wood chisel will work---but might make a woodworker cry--- As to removing the three tiles---scrape out the grout as well as you can---get a small hammer--and start tapping in the center of the tile---remove the center first ,then gently pry out the remains---
Came out just fine... Thanks
Must old thinset be removed when replacing ceramic tile? Doofusboy Tiling, ceramics, marble 2 01-04-2013 09:52 AM
Travertine Tile Help MikeinTexas Flooring 1 09-07-2011 10:43 AM
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 07:48 PM
Mixing Mastic and Thinset in a Tile Job smata67 Building & Construction 2 08-09-2009 10:38 PM
Floor tile - thinset question DyerWolf Flooring 5 05-23-2009 10:39 PM
