Getting Rid Of Dog Smell - Flooring - DIY Chatroom Home Improvement Forum
Old 12-26-2010, 06:54 AM   #1
Getting rid of dog smell
My husband and I are purchasing a house that smells horribly of dog. We know that we have to paint the entire house and change all of the flooring. By doing these two things will we remove the smell? Does anyone know of a treatment that we should do to the concrete slab before laying new flooring? Or a treatment to the walls? Do you suggest changing the floorboards in case of saturation? We've completely remodeled the house that we have now, but have never had to deal with the dog smell. Thanks to anyone with suggestions.
hollilorts is offline   Reply With Quote
Old 12-26-2010, 08:08 AM   #2
the Musigician
DangerMouse's Avatar
Hello and welcome to the forum.
Bullseye 123 shellac will cover most of your smells, ceilings, walls and floors, prior to painting/flooring.
DM
Old 12-26-2010, 09:06 AM   #3
I'd start by removing everything from the house. All the carpet needs pulled up, then scrub the whole place, floor to ceiling with a detergent/water solution and a little elbow grease.
If there is wood over the concrete floor look for stains. If present and depending on the type of floor they can be nutralized. There are dozens of products out there, but beware they may change the finish of the floor. Worst case you need to pull it up. Clean the concrete and let it dry completely. Then use a sealer and your set to install a floor.
A fresh coat of paint on the walls, ceiling and trim will finish the job.
I like to nutralize the odor, then seal everything.
Just my 2
Shamus
Shamus is offline   Reply With Quote
Old 06-04-2011, 09:29 PM   #4
Hi,
My wife and I are in the same situation. We have managed to neutralize some of the dog and cat smells....but not all. Thinking of refinishing the hard wood floors in the entry. Will that be effective?
We washed and painted the floor, walls and ceiling of the garage. After a few months it still smells like wet dog. Ahhhh! Any advice would be treasured.
Half Moon Hack is offline   Reply With Quote
Old 06-06-2011, 10:17 AM   #5
you can go directly to a Pet store and buy special formulated neutralizing cleaners. They work great for animal smells and stains for that matter. Nature's Miracle is a good brand. This type products are specifically formulated for pet odors and stains in floors and carpet.
manandvan is offline   Reply With Quote
Old 06-06-2011, 05:48 PM   #6
Rewards Points: 150
Might need to have your ductwork cleaned as well..
josall is offline   Reply With Quote
Old 06-07-2011, 12:26 AM   #7
Ole Wood Worker
BigJim's Avatar
Rewards Points: 772
I have the same problem so I was going to give this a try.
http://www.zeroodor.com/faq/
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 06-07-2011, 10:04 AM   #8
I have managed 2 pet stores for 16 years and this info spot on, use an enzyme based product. You will apply it and leave it down, if you miss a spot where a dog/cat has urinated you will still have the smell. A black light will help pin point soiled areas.
JohninSC is offline   Reply With Quote
Smell coming from all floor registers. John_W HVAC 10 08-07-2015 06:42 PM
Bad smell in crawl space. John_W General DIY Discussions 34 06-03-2014 12:57 PM
Smell when boiler runs? dave12345 HVAC 13 11-11-2013 08:08 AM
Mold smell in AC houndog HVAC 4 06-03-2010 06:27 PM
Sump pump smell - not sewer Thunderknight Plumbing 3 11-23-2008 08:37 PM
