Getting The First Line Of Laminate Straight - Flooring - DIY Chatroom Home Improvement Forum
Old 11-12-2010, 12:10 PM   #1
Getting the first line of laminate straight
I would like to put down a laminate floor in my older apartment. How do you get the first row of boards straight to the wall so that the rows that follow are going straight. If i just butt them to the wall with the spacers and the wall is not straight to the floor won't the line of boards be on a slant.How do you get the first line straight so all that follows will be straight and not be on a slant
stevenson66 is offline   Reply With Quote
Old 11-12-2010, 12:29 PM   #2
jlhaslip's Avatar
Rewards Points: 946
Using a chalk line, snap a line on the floor. The line should be one width of flooring plus the suggested offset from the wall.
Make marks at each end of the room and snap as long a line as possible.
Measure from this line to the opposite wall to confirm that the last row of flooring will be acceptable, ie: straight to that other wall.
Adjust the snap line if required. May need to erase the first line or use a different colour.
Place the first line of flooring on the line. Tongue out. Then set your wedges behind the flooring to maintain the straight edge.
hope this helps.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is online now   Reply With Quote
Old 11-12-2010, 12:34 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Thanks for the recognition but out of context the comment doesn't mean very much.
XXX
Old 11-12-2010, 12:41 PM   #4
When snapping the chalk line how do you know that the chalk line is straight. Do you line up the edge of the board with the chaulk line
Trying to put down a laminate floor 12mm. This is in an older apartment with walls that are not even. How do you get the first line of laminate boards straight to the wall so that all that follow will not be on a slant
2 threads on same issue merged
Moderator
Old 11-12-2010, 12:55 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
When snapping the chalk line how do you know that the chalk line is straight. Do you line up the edge of the board with the chalk line
Forget the board for now. All chalk lines when pulled tight create straight lines, that's why chalk lines are used to begin with. This is guaranteed.
Let's go through this one more time. Measure out away from the longest wall the width of a board plus the needed gap. Make a mark on the floor with a pencil. Do this at both ends of the room/wall. Then grab a friend to help you stretch the chalk line taught between the two pencil marks.
Snap a line.
Measure from the chalk line mark across to the opposite wall to verify the distances from end to end are basically equal. (It will be a different measurement of course this time.)If they are equal from end to end, you are good to go. If they are not equal some adjustment in the line is necessary to split the difference.
Once the line is final lay-in the first row of boards and install the spacers at the wall. Additional shimming may be required to get the first row of boards to meet the chalk line perfectly. Once the boards are positioned on the line and pushing them towards the wall results in no movement due to the shimming, you are then good to go.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
stevenson66 (11-12-2010)
Old 11-12-2010, 01:00 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
This is a duplicate post. The original post already has comments. This post should be disregarded.
XXX
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 09:00 AM
How to apply a straight line on same wall, two colors AxelF Painting 11 04-09-2010 06:32 PM
Can a roof vent identify where my main sewer line exits the house? YerDugliness Plumbing 8 01-26-2010 05:13 PM
Can't decide: Laminate or Engineered? rogersmj Flooring 7 08-30-2009 09:10 AM
Making a straight chalk line Krichton Building & Construction 11 03-19-2007 08:30 AM
