General Questions On Laminate And Tiling My Subfloor - Flooring - DIY Chatroom Home Improvement Forum
Old 11-01-2014, 02:03 PM   #1
Rewards Points: 12
General questions on laminate and tiling my subfloor
Hi
I have a medical condition and am highly sensitive to chemicals, fumes etc. I am thinking of putting some used laminate down and if I react to it, then I'll probably replace it with tiles.
I currently have floorboards which are quite uneven. If I put laminate:
1) Should I put fibreboard underlay or plywood. Why choose one over the other?
2) How thick must the plywood be e.g. 6mm or 9mm and so on. Is bigger always better and what will the difference be?
3)In case I later change to tile, in this case perhaps its better to start off with plywood? In this case, how thick should it be and will what will the main difference be in size.
Chlorinated is offline   Reply With Quote
Old 11-01-2014, 04:36 PM   #2
Rewards Points: 14,312
Not all floors are able to be tiled even if you went over it with plywood.
Got to start out looking at the size, spacing, and spans of the floor joist.
Old 11-01-2014, 07:03 PM   #3
DIY staff
Rewards Points: 7,174
As Joe mentioned---we can run a span chart on your floor system ,if you tell us what your floor joist length ,size and spacing----
Laminate needs a flat floor--but not an unusually strong one---more info would help--
Old 11-01-2014, 08:16 PM   #4
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 182
And if you are considering tile later on, don't put down thin plywood. It can't be down under tile.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Tiling backsplash over laminate???? mjkpainting Tiling, ceramics, marble 46 07-31-2014 07:06 AM
laminate flooring on top of tile newhomeowner808 Flooring 3 09-19-2009 07:34 PM
Removing Laminate Backsplash??? mjkpainting Remodeling 13 06-22-2009 11:58 AM
preparing for subfloor before tiling zazu2056 Flooring 1 10-29-2005 08:09 AM
