Gearing Up For Engineered Hardwood - Flooring - DIY Chatroom Home Improvement Forum
Old 10-30-2008, 10:11 AM   #1
Rewards Points: 129
Gearing up for engineered hardwood
I'm getting ready to put down 3/8" engineered hardwood. It will be over a crawlspace. Will I need a vapor barrier layed down first? What about roofing felt?
Thanks,
poolecw is offline   Reply With Quote
Old 10-30-2008, 11:05 AM   #2
Floorwizard's Avatar
If your floating the floor, then it will need to be laid over a wood floor pad.
No need for moisture barrier, however it would be nice to see one down in the crawlspace if you do not already have it.
Floorwizard is offline   Reply With Quote
Old 10-30-2008, 12:00 PM   #3
Rewards Points: 129
Thanks...I'm planning on nailing the planks down. The crawlspace has 8 mil poly on the ground. I also have closed cell spray foam applied on the bottom side of the subfloor.
Old 10-30-2008, 03:01 PM   #4
Then no pad is needed, but the felt will be.
Moisture barrier beneath that would be useless with nails going thru it eh?
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 11:56 AM
Hardwood floors: Removal of carpet staples, dried paint, and a discoloration problem proofer Flooring 7 03-01-2008 07:06 AM
How to tell what hardwood... evane Flooring 9 09-06-2007 01:42 PM
