Old 11-27-2009, 10:30 AM   #1
Garage ---> Rec-room flooring issues...
Good day,
I have to appologize right off the start for not knowing alot about this topic, and from what I have already read in this forum, it can be a bit controversial. I have an attached garage on a grade-level concrete slab (11'x21') that I am converting to a family rec-room. It does have some slight moisture (dark areas at times), but nothing extensive. I would like to get some advice on bringing up the floor about 3 inches so that it is level with an adjoining porch, the best methods to insulate and lay a sub-floor, and good choices for the final flooring.
I was initially thinking of laying an initial 6 mil poly on the concrete, then fastening 2"x4" sleepers with a ramset (or the "tapcon" option I read about in this forum). Between the sleepers I'd install rigid styrofoam insulation, then top everything off with groove and tonge plywood and then some sorta flooring. I have also seen those "groove & tonge" 2'x2' OSB sections that have the plastic "stand-offs" used for this type of application, but not sure of their quality.
I am looking to lay down either laminite, carpet, or whatever I can make work (except for tile) for a nice warm atmosphere! I'd like to make it sorta like a bar room feeling!
Can anyone comment on this, and provide a DIY'er some recommendations on the project, what flooring is best, what to avoid, and how to do it so I don't have to tear out and redo because of bad advice from the "apron-wearers" at Home Depot!
jlatulippe is offline   Reply With Quote
Thoughts and opinions on "Trafficmaster Allure" flooring from Home Depot? zel Flooring 826 02-05-2013 03:47 PM
new double garage murray1426 Building & Construction 4 05-23-2009 02:11 PM
Epoxy Garage Flooring boba7523 Flooring 37 02-28-2009 10:24 PM
Garage Door Issues Jenniferd General Discussion 6 01-13-2009 06:12 PM
Can I install Lam Flooring without clearing room? gmhut Flooring 2 08-21-2008 10:23 AM
