Garage Floors - Flooring - DIY Chatroom Home Improvement Forum
Old 10-28-2008, 05:27 PM   #1
Garage Floors
I am thinking about installing a garage tile floor I saw at Lowe's called FlexiTile Interlocking Tile in my garage. It is a soft vinyl tile. Any one use it? Is it easy to install?
Andynme is offline   Reply With Quote
Old 10-29-2008, 10:25 AM   #2
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
It's easy to install. Just whack it together with a mallet. I'm not convinced this stuff if all that great for a garage. I've heard all kinds of people wanting to use it but I've never heard good or bad after than. Supposedly it can withstand commercial traffic, like fork trucks rolling over it.
poppameth is offline   Reply With Quote
Old 10-29-2008, 11:22 AM   #3
Not hard like Race Deck
Thank you, They tell me it is good for the garage traffic and will not buckle or move with cars. But they are getting a new one thicker and a bit harder for commericial that you can drive a fork lift on. I like that it is soft and doen't sound like walking on hard plastic like race deck
Old 11-10-2008, 07:53 PM   #4
im thinking of using urethane as a floor sealant/stain in my garage. comments positive/negative?
dharp is offline   Reply With Quote
Old 11-11-2008, 06:55 AM   #5
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Regular urethanes probably won't hold up the best in a garage. A high solids urethane should work fine. I sell one from P&L called...High Solids Urethane. Comes in 4 colors and clear. From what I've seen it holds up better than the Rustoleum type DIY kits you but at the box stores and it's easier to apply. It's got some powerful fumes though and costs just as much as the kits do.
Old 11-11-2008, 09:17 AM   #6
garage floors
our garage floor will not be used to park cars in, it will be primarily used as a wood shop and storage. im interested in knowing if a concrete stain/sealer can be used.
Mold in detached garage jkrodger Building & Construction 15 05-01-2009 02:46 PM
Light Switch to Detached Garage - Grounding Issue smitty286 Electrical 1 10-22-2008 01:17 PM
Suspended Garage Floors Van Gideon Building & Construction 3 08-05-2008 10:28 PM
double car garage slightly uneven... mcvane Building & Construction 6 11-25-2007 09:41 AM
