Garage Floor Resufacing - Flooring - DIY Chatroom Home Improvement Forum
Old 09-30-2011, 09:15 AM   #1
Garage floor resufacing
As looking to resurface my garage floor. It is all pocked and tough to walk on without shoes. Was looking to use the resurfacer from quickcrete. Looks like you just mix it, dump it and squeegee it smooth. Just looking for any tips or suggestions.
Sent from DJ's iPhone
Djennis20 is offline   Reply With Quote
Old 09-30-2011, 09:53 PM   #2
Originally Posted by Djennis20
Was looking to resurface my garage floor. It is all pocked and tough to walk on without shoes. Was looking to use the resurfacer from quickcrete. Looks like you just mix it, dump it and squeegee it smooth. Just looking for any tips or suggestions.
Old 10-01-2011, 02:13 PM   #3
General Contractor
SeattleSurfaces's Avatar
You should, at the least, scrub with a de-greaser like Simple Green, etch with muriatic Acid, neutralize with ammonia, and pressure wash.
I'd be a little hesitant to just trowel it on without prepping the surface properly. In most cases, we would grind or shot blast the surface since it is difficult to get a good bond if you have hard troweled concrete.
SeattleSurfaces is offline   Reply With Quote
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 10:32 PM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Do I have a Fire Rating Issues with Attached Garage Perry401 Building & Construction 4 04-25-2011 11:58 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
