Garage Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 07-26-2010, 04:39 PM   #1
Garage floor and asphalt sealer
Hello all,
I have a garage floor with a very rough, pitted concrete floor. Several attempts to paint and/or seal has not produced lasting results. Any thoughts on using an asphalt sealer product on a concrete surface ?
Thanks in advance for any comments
Ray
raymojac is offline   Reply With Quote
Old 07-26-2010, 06:16 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
...and how is that going to improve anything?
You could cap it with Self Levelling Compound but all of the previous crap would have to be removed first.
There are Self Levellers that would allow acid staining also. Even decorative impressions in the surface could be achieved.
XXX
Old 07-26-2010, 07:16 PM   #3
Gerry Petard's Avatar
Self-leveling compounds generally aren't advisable for novices to use. People think "self-leveling" = easy, but that's far from the case, much of the time.
Gerry Petard is offline   Reply With Quote
The Following User Says Thank You to Gerry Petard For This Useful Post:
raymojac (07-26-2010)
Old 07-26-2010, 07:38 PM   #4
I guess the only improvement would be No More Dust ! Wonder how paint would adhere to it after a time...
Thanks guys
Old 07-27-2010, 05:57 AM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
raymojac: "Wonder how paint would adhere to it after a time..."
OK now I'm confused! Aren't you the same raymojac that said:
"Several attempts to paint and/or seal has not produced lasting results."
If you are asking about painting the asphalt...forget that! And...if you haven't been happy with paint in the past why would you be happy with paint now?
I'm thinking I'll move on.
XXX
Recommendations for finishing garage floor? bhpizza Flooring 30 01-28-2011 10:09 PM
floor framing in garage chrishallowell Building & Construction 0 06-29-2010 08:04 AM
Water on garage floor kraklowm Building & Construction 2 06-14-2010 03:41 PM
Garage Attic Floor Joists zacmac Carpentry 3 11-02-2009 09:07 PM
Staining a garage floor? Ledge General DIY Discussions 5 07-10-2007 03:57 PM
