Gaps In Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 02-19-2012, 10:45 AM   #1
Gaps in flooring
I just installed new doors, base and casement molding through out my home. In some areas the wood flooring does not reach the new installation and there are a few gaps that I'd like to fill in somehow. What would be the best method to fix these small areas? Here are some pics attached to help understand.
Thanks for any help and thoughts.
www.razorheadsnyc.com/gaps.jpg
ktnyc00 is offline   Reply With Quote
Old 02-19-2012, 11:12 AM   #2
Rewards Points: 12,812
Hate to tell you but the floor was installed wrong.
The jams were suppost to be undercut and the flooring installed under them. There's nothing I can think of that's going to hide that now.
Someone installed the trasition moulding before the baseboards went in.
Base comes first the the strip.
About the only way to fix that is to cut the moulding with an ossilating saw. If you try to remove it, it's going to break off the bottom strip.
Old 02-19-2012, 11:39 AM   #3
Rewards Points: 528
At this point I would use 1/4 round.
framer52 is offline   Reply With Quote
Old wood flooring gaps superman120799 Flooring 1 01-14-2012 09:41 AM
How can I prevent silverfish in the expansion gaps of laminate flooring Cool HOME Flooring 4 07-23-2011 06:13 PM
Allure Trafficmaster flooring gaps theroverguy Flooring 5 09-07-2010 08:21 PM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 09:00 PM
HELP - Gaps in Parquet Flooring dedecv3 Flooring 1 12-02-2006 03:10 PM
