Gaps In Engineered Floating Wood Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 05-17-2013, 12:29 AM   #1
gaps in engineered floating wood floor
is it normal to have small gaps here and there when putting these floors together? I chose the floating floor method and i'm gluing the pieces together. seems like one of the planks were warped. If this is not normal, what is your method of preventing these gaps?
jclee is offline   Reply With Quote
Old 05-17-2013, 08:05 AM   #2
Rewards Points: 13,444
No it's not normal.
Unless your trying to use Bruce brand flooring then nothing would surprize me.
Unless your nailing it down there is no way to close up the gaps when gluing.
Set it aside, may be able to cut it for an end piece and have it work.
Old 08-20-2013, 10:35 PM   #3
X2 unless u have straps set it asside
Godspede619 is offline   Reply With Quote
Old 08-21-2013, 07:00 PM   #4
woodman58's Avatar
You can pull the wood together with 1 1/2" blue painters tape. Pull it together as close as you can and then push the tape to the wood and pull it together. Once you get a few rows together you can start doing every other row as needed. I have done this many times. It works well.
I LOVE THE SMELL OF SAWDUST IN THE MORNING!
woodman58 is offline   Reply With Quote
Resurfacing Mercier's "1/2" premium wood engineered floor rickhunter Flooring 1 10-13-2012 05:54 AM
leveling an installed floating wood floor woody2 Flooring 2 08-02-2010 09:41 PM
tarkett / engineered wood floor installation momof2labs Flooring 13 12-08-2009 05:21 PM
can engineered hardwood be a floating floor? smythe01 Flooring 10 07-09-2008 10:16 PM
Is Cork underlayment the best for a floating engineered floor project? lgkinney Flooring 2 04-05-2008 03:17 PM
