Gap Filler In Engineered Hardwood - Flooring - DIY Chatroom Home Improvement Forum
Old 03-14-2013, 03:25 PM   #1
Rewards Points: 29
Gap filler in engineered hardwood
Hello!
I've heard of many different ways of how to fill gaps in a floor. Unfortunately, my engineered bamboo floor has some ugly and long gaps.
My question is: what is the best way to fill these gaps? I have tried wood filler, but couldn't stain it and it cracked and fell apart. Does anyone recommend wood puddy? If so, how can I harden/seal the puddy?
Thanks a lot!!!
Sundh
Gap filler in engineered hardwood-image-1246114384.jpg   Gap filler in engineered hardwood-image-2409371111.jpg   Gap filler in engineered hardwood-image-4029529869.jpg
sundh is offline   Reply With Quote
Old 03-14-2013, 03:52 PM   #2
Rewards Points: 3,416
The best way to fill the larger one's that appear to be about an 1/8" is to rip a piece of scrap to fill the void,not going to look pretty but better than anything else, that's about the sloppiest job i've ever seen.
Canarywood1 is offline   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
sundh (03-14-2013)
Old 03-14-2013, 07:30 PM   #3
Rewards Points: 13,274
Using strips of wood or any filler is going to crush the wood fibers when the humity changes and it expands.
Only way to get that one right is to remove the flooring up to that point and redo it.
sundh (03-14-2013)
Old 03-14-2013, 07:54 PM   #4
Rewards Points: 29
Thanks Joe!
Do you know if I can salvage most of the planks and reuse them for the "new" installation? I had a hard time finding that kind of floor.
Thanks again!
Old 03-14-2013, 08:11 PM   #5
Depend, is it glued down?
Just looks like common bamboo to me.
First few pieces will get distroyed but the rest should come out if it's not glued.
Old 03-15-2013, 11:17 AM   #6
I agree the only way to do it right is remove and replace,but the expansion and contraction properties of bamboo are different than wood,you only need a 1/4" around the perimiter,so there's no wood fibers to crush as bamboo belongs to the grass family.
Old 03-15-2013, 12:09 PM   #7
Rewards Points: 29
Ok, thanks guys!
I'm gonna salvage as much as I can (it's not glued) and redo it. Thanks for your help.
Old 03-15-2013, 04:32 PM   #8
Professional
UniqueWoodFloor's Avatar
Hi Sundh,
Before installation you want to make sure the flooring is properly acclimated. If you have a moisture meter, you may want to take a reading of the wood in case there are future claims with the manufacture. Also make sure humidity in your home is within manufacture guidelines. This usually means 30-55 relative humidity.
UniqueWoodFloor is offline   Reply With Quote
hardwood on engineered floor? kalpi Flooring 1 09-27-2011 07:32 PM
Installing 3/4" Engineered Hardwood over Particle board New_Floors Flooring 4 01-26-2011 10:23 PM
Dricore and Engineered Hardwood doughboy52 Flooring 0 06-23-2010 09:45 AM
poly on engineered hardwood floor? Constant Improvement Flooring 3 02-03-2009 12:09 PM
can engineered hardwood be a floating floor? smythe01 Flooring 10 07-09-2008 11:16 PM
