-   -   Gap between tub and durock (not lip) (http://www.diychatroom.com/f5/gap-between-tub-durock-not-lip-125107/)
megablok 11-30-2011 11:31 AM
hi everyone!
I'm re-doing a tub tile surround and ran into this problem. After finishing the Durock over a 6mil vapor barrier, I noticed that there is a one inch (almost) gap between the Durock and tub. The other two sides are fine; Durock stops 1/4" above tub lip.
I'm using a 1/2" porcelain tile with 1/4" v-notch trowel. So it covers 3/4" thickness, but there will still be a gap of 1/4" between tile and tub.
Is there any solution to this other than ripping out the Durock and reinstalling it on plywood board to account for gap?
Thanks!
Bud Cline 11-30-2011 11:43 AM
Your tile is only 1/2"? What 1/2" X 1/2" square or what?
What kind of tile adhesive are you using?:)
megablok 11-30-2011 12:18 PM
Hi bud,
The tile is 12x24, 1/2" thick porcelain. I'll be using topflex mortar to lay it.
Thanks.
JazMan 11-30-2011 01:30 PM
Too bad you didn't notice that before.:(
First of all you do not use a 1/4" V trowel for tiles like that. Secondly, the correct trowel, (probably a 1/4x3/8x1/4"), will leave a thickness of about 2/3 the size of the notch. So the trowel I recommend above will leave about 3/16-1/4" (3/8" depth), of thinset. However once you smish the tile into it, it'll add about 3/32" 1/8" max. You'll be lucky if it all adds up to 5/8", but I would want the entire tile inside the tub flange.
You should shim out the wall probably.
Jaz
megablok 11-30-2011 02:55 PM
Thanks Jazman. I will check the trowel this evening. I'm really not excited about removing the durock to shim the wall.:(
I am wondering if someone else had the same problem during the tiling process and did something creative!
Bud Cline 11-30-2011 02:58 PM
Hey mega,
This "gap" of which you speak? Is it a vertical gap from the top of the tub to the bottom of the cement board? If so that's no problem at all.
megablok 11-30-2011 03:26 PM
Hi bud,
Its not the vertical gap. Its horizontal gap. Its between the tub edge and wall. I have posted a picture under the "photos" link above - It is called the TubGap Problem...
Thanks!
Bud Cline 11-30-2011 03:38 PM
Yup, that's a gap, and a fine gap it is too!
When you add the tile to the wall and imagine a little thinset under the tile - how big will the gap be then? It may be caulk-able. Not the best of circumstances. I see why you wouldn't want to shim the wallboard but that's what should have been done even if it meant shimming the entire wall.
You could add another layer of cement board then deal with the edge of that board by cutting tile slivers to dress the edge.:) You could also add another layer of cement board and use extra wide metal tile edging to cover that cement board edge.:)
Is it too late to move the tub a little?
megablok 11-30-2011 09:36 PM
Yeah. I had bought a 5/8" plywood to account for the gap. But in the hurry to finish, forgot to put it up. Aaah. What a predicament.
Cannot move the tub. The tile expert in the store recommended against double layering Durock.
I may just have to take it down and redo it.
Also, I have vapor barrier behind durock. Do I still need to do redguard?
Bud Cline 11-30-2011 09:43 PM
WHAT ?
NONSENSE !
What "tile expert" are you talking about? I hope you aren't talking about Home Depot or Lowe's!
joecaption 11-30-2011 09:50 PM
We always use 1/4 lattice to shim out the walls then the tile board. Far cheaper then two layers of tile board.
JazMan 11-30-2011 10:43 PM
That's great, but he needs to shim out at least 1".
Plywood wouldn't have been such a good idea either.
You should not have both. I believe the surface membrane is much better. I'd remove the one over the studs if you remove the board.
Please let us know where you found a "Tile Expert" at a retail store so we can commend them. :whistling2:
Jaz
megablok 11-30-2011 10:56 PM
@ bud
The tile "expert" at the tile store that is. LOL.
I may just take it down and put furring strips on it. Ugh.
Another question. Is the Redgard needed on top of the Durock if there is vapor barrier behind it?
Also, does the orientation of the Durock board matter? I have some of the boards mounted such that "Durock" reads vertically instead of horizontally.
Thank you!
Bud Cline 11-30-2011 11:21 PM
Either/or, not both.:)
joecaption 12-01-2011 08:40 AM
The direction it's sitting does not matter, the screw heads need to be covered with thin set and the seams need webed tile tape over them set in thin set, sort of like when sheetrocking, Then seal the whole thing with Red Guard, Tile board is not water proof.
