Old 12-31-2012, 10:50 AM   #1
Gap Between Treads and Risers (Rusty Baker??)
All:
I am having carpet installed in 2 weeks in my basement.
They will be carpeting the stairs using waterfall method. My issue is that the stairs were previously open (no risers) and when I made my cuts for the risers, the pine boards were 1/2" short.
Because of where the house construction company nailed the Tread supports, I was forced to place the riser on the face of the tread. Because of this, i wanted to make the riser flush with the tread so no one would trip.
This leaves a 1/2" gap at bottom of riser in the back of the tread. I do have backer pieces glues and screwed to the risers, they are not going anywhere!
It looks incredibly ghetto but does anyone know if this will fly with carpet install? Can they still tuck the corner in? It would go underneath the riser a bit. Thoughts?
Thanks! And no, id rather not go buy all new risers.
Mike
bufddymike is offline   Reply With Quote
Old 12-31-2012, 10:54 AM   #2
Got a picture?
Old 12-31-2012, 10:58 AM   #3
Super Moderator
I think you may have created a non compliant stair case---post a picture if you can---
Stair nose must over hang the riser---flush is not acceptable---at least in this area---Mike---
Old 12-31-2012, 11:08 AM   #4
See attached.
Old 12-31-2012, 11:12 AM   #5
Super Moderator
I'll wait for a stair guy to comment---those would not be acceptable in Illinois---
Old 12-31-2012, 11:16 AM   #6
I think here in NY a nose is not required if tread is min 11" deep.
Old 12-31-2012, 11:20 AM   #7
Super Moderator
Let's see what a stair guy has to say---stair construction always has me cracking open my old books----
Old 12-31-2012, 11:23 AM   #8
But again, my concern is more will this gap be OK for waterfall carpet installation, not so much if it meets code :P
Old 12-31-2012, 11:46 AM   #9
Super Moderator
Rusty Baker is one of the most experienced and helpful installers here---
I'll call him---
Old 12-31-2012, 11:48 AM   #10
Super Moderator
There---Changed your title a bit----he'll give you a proper answer---
Old 12-31-2012, 02:03 PM   #11
Pro Flooring Installer
rusty baker's Avatar
If the carpet is properly installed, tack strip on the back of the tread and bottom of the riser, those stairs will look fine with carpet. I have installed carpet on stairs a lot worse that that. The main thing is that they are solid. And those look very solid.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
oh'mike (12-31-2012)
Tags
carpet, open stairs, risers, stairs, treads
Will these stairs pass IBC code? jonrya91 Building & Construction 21 11-02-2012 09:26 AM
replaced stair treads dhungy Flooring 5 06-20-2012 11:21 AM
Treads and risers Dennisb6 Carpentry 5 01-17-2011 07:13 PM
overhang lenght on treads over risers????? rockey Flooring 3 09-01-2008 08:48 PM
Staining treads, painting risers QueenL Building & Construction 5 04-13-2008 10:23 PM
