Gap Between Hardwood Floor Planks - Flooring - DIY Chatroom Home Improvement Forum
Old 09-21-2011, 08:05 PM   #1
Rewards Points: 29
Gap between hardwood floor planks
Hi, I'm just about getting done putting down my bamboo floors throughout the house. Everything looks really great. I have the floors running from room to room all over and I found it extremely tricky to meet up with the planks from one room to another. I spent a lot of time on measuring and trying to figure out how they'd meet up perfectly flush. Most of the times I had to lay out the floor without nailing it down and see if it all would be flush at the meeting point. I did a really good job everywhere (must have been a lot of luck) except for one spot in the living room where a 2 millimeter gap between a few planks was unavoidable. First of all, what is the best way to measure in order to have everything flush when planks meet up between 2 or more rooms?? Secondly, what is the best way to fill these gaps to make it look flush and unnoticeable?? Should I use a wood filler or urethane caulk? The floors are pretty dark and I'd like to get something that looks identical to the floors and that looks/dries like wood. Thanks a million in advance!!
Best,
Marcus
sundh is offline   Reply With Quote
Old 09-22-2011, 07:42 AM   #2
woodman58's Avatar
Rip a few peices of flooring down to the width of the gap and glue the peices in the gap.
I LOVE THE SMELL OF SAWDUST IN THE MORNING!
woodman58 is offline   Reply With Quote
Old 09-22-2011, 08:19 AM   #3
Rewards Points: 256
I would have thought there would have been a way to put that gap at a wall(under a baseboard). Not seeing your layout I won't seccond guess you.
I doubt you will be able to rip a 2mm piece of bamboo. To fill in. I reccomend either eliminating the gap, or filling with wood putty.
michaelcherr is offline   Reply With Quote
Old 10-03-2011, 09:24 AM   #4
Rewards Points: 150
I just put a threshold/transition peice between my two rooms. Disn't have to worry about blending the two together.
joemontana16 is offline   Reply With Quote
Old 10-03-2011, 09:28 AM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Why are there gaps?
Why are the gaps "unavoidable"?
Installing new hardwood ontop of existing hardwood benshouse Flooring 4 01-10-2014 12:45 PM
3/4 Hardwood Flooring over sufficient subfloor? bout time Flooring 3 06-20-2011 05:15 AM
Lay New Hardwood On Hold Hardwood TJfive0 Flooring 3 04-30-2011 05:50 PM
Installing 3/4" Engineered Hardwood over Particle board New_Floors Flooring 4 01-26-2011 09:23 PM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 11:56 AM
