-   -   Gap appearing, solutions? (http://www.diychatroom.com/f5/gap-appearing-solutions-192459/)
RyanD 12-22-2013 08:12 AM
2 Attachment(s)
I think it's because of the small space for the doorway and on each site is 12-15' of flooring trying to pull this little strip both ways and the kitchen side won I guess. :huh: I'm not sure taking up the floor (floating) and fixing it will help since it will probably happen again with seasonal changes and it would be a pain in the ass to do that now so I'm thinking of just using a circular saw to cut a strip down the middle of that board to remove it and then adding two small pieces with a threshold there instead. Not ideal to have a bump threshold there but better than I gap I think.
This is also happening on the other side of the wall where again there are two sides pulling on a single board but it's not as bad and there is no easy way to add a threshold there.
joecaption 12-22-2013 03:13 PM
Is that laminate?
There was suppose to be a transition strip at the opening.
I'm also not seeing an expansion gap along the wall in the bottom picture on the right side of the wall.
The flooring was also not run under the door jamb.
RyanD 12-22-2013 03:25 PM
Originally Posted by joecaption (Post 1281626)
Is that laminate?
Hardwood bamboo. Why a transition, they manufacturer said one is only needed if it spans > 30'. There is expansion under the trim all around. The part missing under the door jam bugs me too which I could fix by putting a transition in too
woodman58 12-22-2013 05:01 PM
The product is stranded bamboo. It is very stable as for expansion and contraction. How long has the floor been installed? It does not look like it would have shrunk that much.
RyanD 12-22-2013 07:49 PM
five months. It was installed in the summer (80-90s) and now it's winter. Could it just be a bad piece. I did have to bad lip on another piece that did the same thing and I replaced it. Replacing this would be a pain since I'd have to rip up an entire side of the room to get to it.
Canarywood1 12-22-2013 09:12 PM
That jamb needs to be undercut for that piece to slide under.
woodman58 12-23-2013 06:52 AM
Here is a link on "How to Replace a board".
http://hardwoodfloorsmag.com/article...id=22&zoneid=2
RyanD 12-23-2013 06:58 AM
Thanks, I might do that. It's click so it's not nailed down but it's made to click into each other so not sure how well it will work if it's not (using the method from the link). I guess I can always try this method first and if it fails pull up the entire floor to fix it. :whistling2:
woodman58 12-23-2013 07:26 AM
I'm sorry. I did not know it was clik Lock. The method in my last post is only for regular tongue and grove flooring. The best way to repair this is to take the floor apart. If you feel it might do this again, you can put a bead of glue in the grove before putting them together. Keep a damp rag handy to wipe up access glue.
RyanD 03-31-2014 09:13 AM
1 Attachment(s)
Hey, so the gap is much wider now. I was able to fix the one in the doorway but installing a t-modling but the other side of the wall doesn't have an easy way to do that. Here's a photo, the two arrows point to the parts of the floor that have the gaps. It's noticeable not only by seeing it but you can feel it with your foot now so it's annoying/dangerous. Would installing a threshold here look odd/work? Do I have any other options? If I pull up the floor and glue these pieces (suggested by flooring company) wouldn't the gap just appear at the next weakest point?
yes there are gaps all the way around, the floor is under the molding. It's a floating floor.
