Fuzzy Stuff Growing On Basement Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 11-05-2010, 10:37 AM   #1
fuzzy stuff growing on basement floor
What it is I have no idea. We have had a very wet year, it is growing under the carpet as well as in the furnace room without carpet. The house was built in 1980 and one contractor thought it may have been fiberglass concete. I would like to get rid of the fuzzy stuff .
peggy whiting is offline   Reply With Quote
Old 11-05-2010, 07:40 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Mold. Get rid of it immediately.
XXX
Old 11-05-2010, 08:00 PM   #3
Don't know it all, yet!
Second!
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 11-05-2010, 11:54 PM   #4
jlhaslip's Avatar
Rewards Points: 2,132
Originally Posted by downunder View Post
Second!
Same answers here...
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 11-06-2010, 06:09 AM   #5
Rewards Points: 1,512
A good soaking with bleach. Not just a spray or moistening. Cover every square inch. Remove and discard the carpeting.
If it is white, it could be some of the chemical content of the concrete separating and returning to the surface. This is called efflorescence (no U), also brought about by moisture coming through from the outside. It would be removed using muriatic acid followed by a good rinse. But since you don't know for sure, do the mold killing first.
Old 11-06-2010, 08:06 AM   #6
pest control operator
Google efflorescence and see if that is what it is before you do anything for mold that may/may not exist. It is a salt that leaches out of the block/concrete due to higher than usual moisture levels, or at least higher than previous.
PAbugman is offline   Reply With Quote
Old 11-06-2010, 11:46 AM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Mold is a bacteria and would be fuzzy/hairy and soft while efflorescence is a form of mineral and would be somewhat crusty and harder and in some cases crystallized.
Mold spores become airborne and can be very harmful to your respiratory health while efflorescence doesn't usually become airborne without being disturbed and has no real health issues.
Err on the side of caution and treat for mold first.
XXX
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
Laminate floor in basement questions ryoung25 Flooring 8 09-15-2010 10:33 PM
Basement floor drains zantar Plumbing 13 07-31-2010 09:15 AM
New drains under the basement floor, guidance needed mason Plumbing 6 01-10-2009 04:58 PM
