Free Float - Wood Plank Sinks In/springs Back Up - Flooring - DIY Chatroom Home Improvement Forum
Old 08-18-2008, 02:56 PM   #1
Free float - wood plank sinks in/springs back up
I hired a contractor who recently installed a pre-engineered wood floor using the free-float installation method, with a foam and cork underlayment over ceramic tile. Everything looks great however I am now noticing that in one area, two wood planks (adjacent to each other) sink down/spring up when I walk over it.
Are there any suggestions on what could be done to fix these two problem areas?
RobertFSU is offline   Reply With Quote
Old 08-20-2008, 09:14 AM   #2
Get out of the box!
Rewards Points: 260
I assume it is a Low spot in the floor this can be fixed with a tarpaper build up in the low area
Schluters Kerdi Shower System, Ditra. Loxcreens ProVa Mat Shower Systems
Konecto Luxury Vinyl Plank,Armstrong and Hardwood flooring.
https://IndianaFloorsLLC.com/default.aspx
26yrsinflooring is offline   Reply With Quote
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
Giving back - Free trellis plans Brik Landscaping & Lawn Care 0 06-27-2008 08:20 AM
