Framing Tile Fireplace With Hardwood How Do You Determine The Cut/angle? - Flooring - DIY Chatroom Home Improvement Forum
Old 08-11-2012, 08:27 PM   #1
Framing tile fireplace with hardwood how do you determine the cut/angle?
Hello,
I am trying to install hardwood flooring in my living room. I have a tile fireplace that I want to frame around the hearth with the hardwood and then continue the flooring into it. How do you determine the angle of the cuts?
pbthompson3168 is offline   Reply With Quote
Old 08-11-2012, 09:03 PM   #2
Rewards Points: 13,458
Since no one here know what it looks like or what pattern your looking for it's had to say.
A simple bevel gauge or a Starett 505-7 will work.
Just Google them if you do not know what they are.
Old 08-11-2012, 09:33 PM   #3
I am trying to determine the degree of the cut, I shouldn't matter what it looks like. I would assume there is. Trick to determining the degree.
Old 08-11-2012, 09:40 PM   #4
Most hearths are nothing but a rectangle, so no one here knows why you need anything but 90% cuts unless they can see what the problum is.
Old 08-11-2012, 09:43 PM   #5
I have 12x12 tile in a rectangle a both ends I cut a tile in half so I am guessing is close to a 22.5 but I dont wan to guess what to guess what to set my miter saw at.
Old 08-11-2012, 09:44 PM   #6
Tile cut in half on a diagonal.
Old 08-11-2012, 09:44 PM   #7
Then use one of the two tools I posted.
Old 08-11-2012, 09:45 PM   #8
I don't have those tools what are they?
Old 08-11-2012, 09:46 PM   #9
I have squares would work?
Old 08-12-2012, 06:55 AM   #10
DIY staff
Rewards Points: 7,174
Tell us what the original angle is---and we will divide that in half (the miter angle) for you.
Tile to Hardwood Transition politronics Flooring 7 11-29-2011 04:55 PM
OK to tile over vent/gaps on brick fireplace? roxksears Remodeling 4 01-22-2010 12:48 AM
Hardwood transition to ceramic tile willyberger Flooring 5 08-09-2009 11:38 AM
Fireplace framing question gobble Building & Construction 2 05-17-2008 10:01 PM
fireplace framing sonic_loser Building & Construction 1 11-02-2007 12:35 AM
