Found Leak Now The Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 08-17-2013, 11:01 AM   #1
Found leak now the tile
My question is now that I have found and fixed the leak should I pull up the effected ceramic tiles that had water seeping through the grout or just clean out the grout and let dry and then replace grout? I am thinking I should go ahead and pull up tiles and let dry.
double bogey is offline   Reply With Quote
Old 08-17-2013, 06:52 PM   #2
DIY staff
Rewards Points: 7,174
If the tile is set over concrete or cement backer---you may be all right to let it dry out.
Is there a reason to rip out the tile right away? If not--wait and see--
Fixed water leak not drying under tile floor around toilet WinstonWolf Plumbing 1 05-19-2013 04:40 PM
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
new ceramic tile over 12x12 ceramic danthebuilder Tiling, ceramics, marble 4 08-09-2011 12:03 PM
leak in cement tile roof virgo822 Roofing/Siding 2 07-23-2011 05:29 AM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
