Footprint In Epoxy Grout - Flooring - DIY Chatroom Home Improvement Forum
Old 12-10-2010, 09:45 PM   #1
footprint in epoxy grout
I'll make this quick: girlfriend walked on epoxy grout before it was ready for foot traffic. Now you can see footprints on the tile if light reflects off of it. Is there anything I can do to fix this?
Tonglebeak is offline   Reply With Quote
Old 12-10-2010, 11:20 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Yes there is.
XXX
Old 12-11-2010, 08:20 AM   #3
Rewards Points: 1,580
Get a grout removal tool, remove as per need, and regrout.
bob22 is offline   Reply With Quote
Old 12-11-2010, 11:30 AM   #4
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
If it is fairly fresh scrub it with a white scotchbrite pad and a diluted mixture of vinegar and water. The acid in the vinegar should take up the haze if it isn't cured completely yet. Sound like you have haze and footprints on the surface of the tile where she walked. If the vinegar doesn't work an epoxy haze remover is in order. As for the grout line you can cut it out if it needs regrouted but epoxy is a pain to remove.
poppameth is offline   Reply With Quote
Epoxy Grout? Suggestions Branden Flooring 4 08-10-2010 05:48 AM
epoxy grout on glass tiles? zootjeff Tiling, ceramics, marble 1 07-04-2010 07:21 AM
Epoxy Grout Removal FLWRCHLD Flooring 2 05-26-2009 11:02 PM
Repairing Epoxy Grout? Ed Coles Flooring 2 01-22-2009 06:40 PM
epoxy grout?? samiam Flooring 1 12-04-2007 09:24 PM
