Folex Carpet Cleaner On Pet Urine - Flooring - DIY Chatroom Home Improvement Forum
Old 12-31-2013, 01:37 PM   #1
AussieWendy's Avatar
Folex Carpet Cleaner on pet urine
Has anyone ever used? Does it only get the stain out and not the smell?
If I use this to get the stain out should I use odorban after or just skip the Folex and go straight to the Odorban.
Thanks!
Wendy
AussieWendy is offline   Reply With Quote
Old 01-03-2014, 12:55 PM   #2
Rewards Points: 704
Use an enzyme-based pet-mess cleaner. All pet stores, and most grocery stores carry them. You soak the carpet down to the pad, let it sit for a while, then blot it up. The enzymes will break down the pet smell, though you may need to perform several applications. If any stain remains, then hit it with the Folex.
Rather than blotting, I like to use a small Bissel machine to suck up any liquid from the carpet. It leaves less detergent behind, which can make stains reappear down the road.
Seattle2k is offline   Reply With Quote
Carpet Flooding and Replacement airjay81 Flooring 1 05-08-2012 01:00 PM
Bissell Proheat Carpet Cleaner vtcarol50 Appliances 6 11-13-2010 12:05 AM
Cat urine in carpet Angela3511 Flooring 8 07-15-2010 02:46 AM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 08:48 PM
