Floors Sweat - Flooring - DIY Chatroom Home Improvement Forum
Old 08-08-2010, 11:28 PM   #1
Floors sweat
In my kitchen and den, I have ceramic tile..It sweats and always looks dirty.I bought a dehumidifier and within 8 hrs, it has reached it 25 pint capacity..Is this normal, what makes the floors sweat so bad
mixiesmama4ever is offline   Reply With Quote
Old 08-09-2010, 12:38 PM   #2
Moisture is coming from somewhere. Either from the conditioned (I am assuming this is an A/C space) air or from the ground. There are a lot of possible causes. Is your AC properly sized? If it is oversized then you aren't pulling out as much moisture as you should be. Where do you live? Do you open exterior doors/windows frequently to allow large bursts of warm, moist air inside? If you live in a very wet climate, is there proper drainage from your slab? Are you on a slab, or a crawl space.
Guess what I am trying to say is that there needs to be some additional info. Let's start with -
1. How old is the house?
2. Slab or raised foundation?
3. AC sizing?
4. Where do you live?
unlvrebel is offline   Reply With Quote
Resurfacing Wood floors roxksears Building & Construction 2 10-23-2009 08:50 AM
Refinshing floors before painting walls? ponchoman1 Flooring 6 03-14-2009 04:21 PM
damage to prefinished floors normal during a remodel? zzman Remodeling 15 12-04-2008 05:25 PM
Want to try to refinish hardwood floors and parquet floors proofer Flooring 11 04-20-2008 05:59 PM
Washing my wood floors J187 Flooring 1 11-14-2006 10:13 PM
