Old 08-13-2008, 04:36 AM   #1
Question
Floors meeting under doors
Two rooms with a connecting door have different floor coverings. There is a narrow threshold strip at the join. How should this strip be placed relative to the door?
It is clear that, with the door closed, the flooring of one room should not be visible from the other. My gut feeling is that the room into which the door opens "owns" the door and that the join should be immediately underneath the outside of the door thus defined, hence half of the threshold strip would be under the door and half in the room that does not own it. However, what is correct?
Graham_in_Devon is offline   Reply With Quote
Old 08-13-2008, 09:27 AM   #2
Tileguy
Bud Cline's Avatar
Typically the center of the door rules. But since you have put so much thought into your conclusion go ahead and do it your way.
Old 08-14-2008, 03:30 PM   #3
Thanks Bud.
I have now researched other properties, well two anyway, and have discovered that the centre of the door does indeed rule. Three out of three is enough for me! I will do that. Thanks again.
Graham_in_Devon
UK
Tags
doors, flooring, threshold
UGH! A lesson for new Pre-Hung Doors javan General Discussion 6 08-08-2008 08:47 PM
Replacing all doors and trim...lots of questions... Badfish740 Carpentry 5 07-27-2008 01:16 PM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 06:04 PM
French Doors That don't Match! terryb Building & Construction 21 12-17-2007 08:19 PM
Home Made Closet Doors allen1466 Building & Construction 9 10-25-2007 05:57 PM
