Old 01-17-2010, 07:17 PM   #1
Flooring for Unheated Seasonal Cottage
Hello,
Does anyone have any experience or recommendations for flooring for kitchen and bath spaces in a cottage that will be unheated for most of the winter? We are building on a remote site, and while we will use it for short periods during the winter during which it will be heated, for most of the winter it will be unheated. The floor is open below, but will be spray foamed. Temperatures will range from -40F in cold snaps to +95 in the summer.
We have thought about vinyl and linoleum but wonder how it will do over time.
Thanks.
ptarmigan61 is offline   Reply With Quote
Old 01-17-2010, 07:43 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Painted plywood. I know of no flooring product that will stand those temperature extremes.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
framer52 (03-22-2012)
Old 01-17-2010, 11:01 PM   #3
nothing will hold in those conditions..you are going to have tons of problems not controling the temp. in that kind of climate.not just with your floors.
just tile is offline   Reply With Quote
Old 01-18-2010, 07:43 AM   #4
You will need to regulate the temperature to some degree if you want to put any type of laminate or hard surface in. Laminate floors have less movement with expansion and contraction problems. It could be worth contacting Quickstep who are the market leaders to ask their opinion
Last edited by Scuba_Dave; 01-18-2010 at 09:18 AM. Reason: removed advertising links
Dean Heath is offline   Reply With Quote
Old 01-18-2010, 07:45 AM   #5
roll out carpets
Old 01-18-2010, 11:08 AM   #6
Loose-lay rugs might work, Stretch-in carpet won't.
Old 01-18-2010, 12:45 PM   #7
Newbie Bill
I'll share my experience. We have a 25 year old cottage. Used only occasionally in the winter. So our cabin may not have the same heat / freeze cycles yours may have. We had vinyl flooring in the cabin from day one. The only issue we had was a poorly completed seam started to lift. A few years ago we installed a laminate floor and some tile. No issues whatsoever.
In my opinion, I would say vinyl will hold up just fine. It's a cabin after all.
How do you plan to heat the cabin? Personally, I would be more concerned about water in the plumbing.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 01-18-2010, 12:55 PM   #8
Xtreme DIY'r
I have a friend whose family owns a beach cottage
Its empty from maybe early Dec until March, sometimes longer period
It's been in their family for decades
They have just linoleum down, no insulation under the floor
Its been that way as long as I have known him - over 15 years
Temps do not get down to -40, maybe -10 or so at the Max every few years
Old 01-18-2010, 01:04 PM   #9
the Musigician
DangerMouse's Avatar
float a cork floor on it for beauty and warmth.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 01-19-2010, 02:34 PM   #10
Thanks for all the tips. My grandparents place had battleship linoleum in it, and it seemed to fare OK. That was a long time ago, though, and I was pretty young - don't remember much.
Old 01-19-2010, 11:34 PM   #11
Seagate flooring wood probably be best for the conditions. But still need to regulate temp. Above 32 degrees. Good luck.
Old 01-20-2010, 07:39 AM   #12
Whatever you do, it will probably have to be a DIY project. No flooring installer will want the liability.
Old 07-07-2011, 09:39 PM   #13
Question
Hi,
We are building a cottage in Alberta that will undergo similar extremes -- just wondering what kind of flooring you ended up using and how it is working out.
Thx.
free2run88 is offline   Reply With Quote
Old 10-04-2011, 02:21 PM   #14
Hi,
Used a Terraco laminate tile in the Master bedroom, painted floors so far in the others, Pine plank in the living room, and have posted a new question about Snapstone and related products recently because we were hoping to do that in the bathroom and kitchen area.
Old 10-04-2011, 09:40 PM   #15
Smile
Hi,
We ended up using a floating laminate made by Dupont with the underpad attached the laminate. The snapstone tiles sound interesting. If we ever upgrade the current floor we will keep that option in mind. This will be the floors first winter so we will see how it fares. Since then our basement flooded so maybe we'll check out the snapstone for that area. Always another job
Laurel
Strange engineered wood flooring install in Philippines (pics) Flt_Simulation Flooring 7 10-05-2009 10:00 AM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 09:00 PM
no glue, no nails wood flooring - little help? reds_21 Flooring 2 02-13-2009 12:32 PM
