Flooring Under Fireplace Gas Valve Trim Ring - Flooring - DIY Chatroom Home Improvement Forum
Old 02-09-2012, 09:57 AM   #1
Flooring under fireplace gas valve trim ring
Next to our fireplace on the floor is a round chrome trim piece that goes over the turn-key for the gas valve.
I thought that I could simply pull the trim collar out of the floor, cut the hardwood planks around the hole and then replace the trim collar, but the trim collar doesn't want to seem to be lifted out.
Are there any tricks to removing these things?
stankholio is offline   Reply With Quote
Laminate Flooring around Curved Fireplace Dallas Flooring 9 03-01-2011 01:47 AM
Need to ID Gate Valve (Please Help) MikeGV Plumbing 3 10-04-2010 11:02 AM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
How to install thermostatic reactive valve and repack supply valve Leah Frances How To Guides 1 06-10-2009 10:49 AM
Leaking pressure relief valve Chris Magee Plumbing 12 08-12-2008 07:48 PM
