Flooring Transition Help. - Flooring - DIY Chatroom Home Improvement Forum
Old 06-17-2013, 10:46 AM   #1
Flooring transition help.
I have a transition between wood floors and slate tile that I need to cover, but there's about a half inch difference in height. What kind of covering do I use and how do I even out the transition so we're not constantly tripping over it. Thanks.
jtienor is offline   Reply With Quote
Old 06-17-2013, 11:50 AM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,764
You can go to the big box, in the flooring aisle, andpossibly find a workable and semi-matching transition strip... in wood or metal.
I think it is easier to just cut on to your exact specs, and probably stain it up to your wood floor color.
MTN REMODEL LLC is online now   Reply With Quote
Old 06-17-2013, 05:59 PM   #3
Rewards Points: 3,624
What you need is a reducing strip,it butts right up to the high side.
Canarywood1 is online now   Reply With Quote
Old 06-17-2013, 07:58 PM   #4
Rewards Points: 264
I agree.. A reducer would work best. Their is a picture of one right here http://www.exotichardwoodflooring.co...ng-accessories They have these at most box stores. Hope this helps.
Awoodfloorguy is offline   Reply With Quote
Old 06-17-2013, 08:05 PM   #5
Do you have a table saw.... just cut one to custom fit. Regardless of my flooring, (unless a light maple) I just use a piece of oak (for being hard), stain it up, two three coats of a floor poly, screw it down.... seems to me much easier than chasing something at the stores.
At 1/2 " differential (with the tile higher) I generally will butt (not lap) that transition to the tile and grout it... just as said by other above.
Transition on stair step from laminated flooring deck hand Flooring 7 01-22-2013 01:35 PM
Allure flooring transition between hallway, bedrooms, and bath? amtrak23 Flooring 3 09-23-2012 05:30 PM
Transition of Hardwood Flooring on Stairs rkirby Flooring 1 02-02-2011 06:06 PM
laminate flooring - transition suncowiam Flooring 4 09-11-2009 10:37 AM
Hardwood Flooring transition msfmatt Flooring 2 05-21-2009 07:57 AM
