-   -   Flooring transition help. (http://www.diychatroom.com/f5/flooring-transition-help-181981/)
jtienor 06-17-2013 11:46 AM
I have a transition between wood floors and slate tile that I need to cover, but there's about a half inch difference in height. What kind of covering do I use and how do I even out the transition so we're not constantly tripping over it. Thanks.
MTN REMODEL LLC 06-17-2013 12:50 PM
You can go to the big box, in the flooring aisle, andpossibly find a workable and semi-matching transition strip... in wood or metal.
I think it is easier to just cut on to your exact specs, and probably stain it up to your wood floor color.
Canarywood1 06-17-2013 06:59 PM
What you need is a reducing strip,it butts right up to the high side.
Awoodfloorguy 06-17-2013 08:58 PM
I agree.. A reducer would work best. Their is a picture of one right here http://www.exotichardwoodflooring.co...ng-accessories They have these at most box stores. Hope this helps.
MTN REMODEL LLC 06-17-2013 09:05 PM
Do you have a table saw.... just cut one to custom fit. Regardless of my flooring, (unless a light maple) I just use a piece of oak (for being hard), stain it up, two three coats of a floor poly, screw it down.... seems to me much easier than chasing something at the stores.
At 1/2 " differential (with the tile higher) I generally will butt (not lap) that transition to the tile and grout it... just as said by other above.
