Old 08-10-2012, 03:53 PM   #1
Flooring suggestions for the "urine gone" floor
The primer seems to have worked covering the urine odor. Can I install some laminate wood (cheap and easy for me to do) to cover the plywood recently Primed. It is on the 2nd floor and we are undecided if to re carpet or simply get some flooring
tennisdoc1 is offline   Reply With Quote
Old 08-10-2012, 04:07 PM   #2
Is the pet gone that was causing the problum?
Just keep in mind laminte floor will be cold to walk on bare foot, will tranfure sound down stairs far more and will sure no increace the value of the home.
Old 08-11-2012, 06:35 AM   #3
The stains were all there from the original owner as we have pets but not causing any of the issues. Good point about the noise level and value concern but it real is a cat room and storage area currently. No one but the cat in the room. We are not ready for the whole house to be re done and thought the flooring as a start. May simply buy a area rug.
Old 08-11-2012, 07:27 AM   #4
sdsester's Avatar
Your call I guess. I am not a big fan of cheap laminate flooring but I guess real quality stuff might work for your situation. Just make sure you get something with enough laminate it will stand up to pet claws or plan on putting an area rug over it.
sdsester is offline   Reply With Quote
Old 08-11-2012, 07:33 AM   #5
I agree as have the laminate in the kitchen and to me looks cheap--but I did not buy it--may just keep it as a loud white color floor--echoing!
Hardwood flooring under sub floor Dollface Flooring 7 10-17-2011 11:12 PM
Installing laminate flooring over wood floor. onenonlydano Flooring 0 03-06-2010 10:26 PM
Need suggestions for workshop floor campchair Flooring 9 02-04-2010 10:06 PM
Hardwood floor questions (56K) ukrainetz Flooring 1 08-02-2009 02:08 PM
